Results 1 to 9 of 9
Thread: HSS bit profile for boring head?
27th Aug 2018, 06:01 PM #1Senior Member
- Victoria, Australia
- 114
I want to use my boring head with a HSS bit for boring. What type of tool bit grind is best?
Should I grind a general right hand roughing profile, or maybe a basic round nose or maybe a knife-edge profile or maybe a screw cutting profile?
What do members recommend?
Sincerely,
Tom
27th Aug 2018, 06:19 PM #2Most Valued Member
- 4,890
Depending on what you are boring and the type of opperation and finish you want grind it the same as you would if you were doing the job in the lathe.
27th Aug 2018, 06:22 PM #3Senior Member
- 114
Makes sense. I might grind the bit and turn in the lathe and see how it performs. I wonder if boring requires special considerations. I will start with some free machining aluminum.
27th Aug 2018, 06:48 PM #4Most Valued Member
- 4,890
The only thing to be aware of is the ridgidity, when using the boring head as you may find the bar will be much further away from support compared to when held in the lathe tool post.
27th Aug 2018, 06:49 PM #5Senior Member
- Dec 2013
- 201
A couple of things to look out for:
If the bore diameter is small relative to the HSS tool size, you may need to round off the back part of the ground tool so that it doesn't hit the bore behind where the cut is taking place.
Depending on how much stick out you have from the boring head, a large nose radius on the cutting edge may produce chatter. I always use a fine radius on boring head tools, use low feed rate, and take my time with the cut.
Plasticine is great for killing chatter. Even a small amount wrapped around the bar can provide enough damping to kill a resonance.
Graham.
28th Aug 2018, 08:55 PM #6.
- 6,459
Tom,
When I fly cut the bases of a couple of hand shaper tables for Bob L and myself I used an Ausee fly cutter with its as supplied piece of ground HSS . Basically the same ground reliefs as a lathe tool. Worked well on the sand cast cast iron. No real reason why it wouldn't perform just as well in a bore.
https://www.ausee.com.au/shop/category.aspx?catid=8361
Bob.
28th Aug 2018, 11:09 PM #7Senior Member
- 114
Thanks Bob, I'll get some HSS bits and experiment. Excellent response.
29th Aug 2018, 08:48 PM #8
29th Aug 2018, 10:52 PM #9Plasticine is great for killing chatter. Even a small amount wrapped around the bar can provide enough damping to kill a resonance.
Interesting idea.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
Boring Head
By scottyd in forum METALWORK PROJECTSReplies: 11Last Post: 1st May 2016, 08:48 PM -
What is this boring head used for?
By jhovel in forum METALWORK GENERALReplies: 7Last Post: 23rd Sep 2011, 10:12 PM -
CTC Boring Head
By Anorak Bob in forum METALWORK GENERALReplies: 41Last Post: 12th May 2011, 08:31 AM -
Boring Head Dissection
By Anorak Bob in forum METALWORK GENERALReplies: 1Last Post: 30th Jan 2011, 05:23 PM -
SOLD: 50mm-mt3 shank precision boring head & boring bar kit
By SurfinNev in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 15th Jul 2010, 02:42 PM
