Results 16 to 25 of 25
Thread: DIY Tap wrench
29th Aug 2018, 07:03 PM #16
29th Aug 2018, 07:15 PM #17Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
29th Aug 2018, 10:52 PM #18Golden Member
- Sep 2008
- 838
I have a few of the barrel type as well, Moore and Wright and an unknown brand, possible military going by the symbol that can be seen on the handle.
30th Aug 2018, 11:05 AM #19Most Valued Member
- 4,258
30th Aug 2018, 02:24 PM #20Senior Member
- Brisbane
- 143
I know what you mean.. I have never used one, but I would assume it relies on the hardness of the hole, and the end of the screw being faced square ...once tightened against a flat, the tap cannot move or twist !
The other type with the "V" can hold the tap the same way (flat against the screw), or diagonally.. with the screw on one of the corners..a right and a wrong way, perhaps !
maybe someone from the UK can clear this up.
31st Aug 2018, 04:31 AM #21
I have one of the round barrel type. The "V" jaw is not a problem, but the force to hold the tap into the "V" is just the end of the screw, which is a flat. The screw on mine is not hardened, it is still soft and has become mushroomed over time. The net result is the screw can be no longer removed. Other than that it works just as well as it always did.Best Regards:
31st Aug 2018, 11:43 AM #22Senior Member
- Brisbane
- 143
Hi WoodBee2
I have to work out what sort of steel to use .. mild steel and case hardening would be the easiest with regard to my heating capabilities ... will certainly put up pics of the build.
Ken.
31st Aug 2018, 01:48 PM #23I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
A timely post, Eskimo - the little V-Jaw in my tap wrench split right half in two just a couple of days ago, so I need to replace it. Never seen the style in your first post before, but I like it, and shall build one henceforth. Err.... maybe next week... Or year....
31st Aug 2018, 03:18 PM #24Most Valued Member
- 4,258
31st Aug 2018, 06:37 PM #25
I broke my torque wrench
By jack620 in forum METALWORK GENERALReplies: 9Last Post: 20th Feb 2018, 08:03 AM -
Collet Nut Wrench
By BaronJ in forum METALWORK GENERALReplies: 3Last Post: 28th Aug 2015, 11:17 PM -
HIT Piipe wrench
By WesP in forum METALWORK GENERALReplies: 6Last Post: 24th Feb 2014, 09:09 PM -
Open end wrench as a caliper.
By aametalmaster in forum METALWORK GENERALReplies: 7Last Post: 9th May 2012, 12:39 AM -
Impact Wrench
By electrosteam in forum METALWORK GENERALReplies: 9Last Post: 27th Jul 2010, 11:52 PM
