Results 1 to 4 of 4
25th Aug 2018, 11:22 PM #1Member
- Apr 2018
Lathe chuck removal shaft collar wedges
Hi all!
I have come up with a great idea which allows for very easy removal of chuck from a threaded spindle.
The part is made of plastic so it wont damage the threads and sits on the spindle behind the chuck which can be slammed on hard, and removed just as easily.
No need for any spindle locks, back gears, etc.
All that is needed is a screwdriver.
I have so far run the lathe and the chuck has not come loose.
25th Aug 2018, 11:46 PM #2Most Valued Member
Sounds like a fantastic idea, will it fit any threaded nose? Asking as I have a WW lathe also.
26th Aug 2018, 12:03 AM #3Member
- Apr 2018
I can custom fit it to any threaded spindle machine, all I need is the diameter of the spindle and spindle length (the part currently takes 6mm from the spindle, maybe some tweaking can get it down to 4mm).
Currently I have it equipt on a Hercus 260G, I have removed the chuck about 4 times now and the part is still in great condition, so it can be used multiple times despite it being made of plastic.
27th Aug 2018, 06:35 PM #4Member
- Apr 2018
I am planning to make these chuck removal wedges and sell them for $15 a set + shipping (have to check at post office, probably around $5).
There will be no extra cost for custom sizes, they will just be added to the size database.
Help With Drill Press Chuck Removal
By hitch in forum METALWORK GENERALReplies: 29Last Post: 17th Aug 2019, 11:16 PM -
Chuck removal device
By morrisman in forum METALWORK GENERALReplies: 15Last Post: 2nd Jun 2013, 08:31 PM -
chuck removal ..spindle old
By morrisman in forum METALWORK GENERALReplies: 22Last Post: 23rd Jan 2012, 05:23 PM -
Pistol drill - chuck removal etc
By Bryan in forum METALWORK GENERALReplies: 10Last Post: 12th Dec 2011, 10:45 AM -
Chuck removal
By Godzilla98 in forum THE HERCUS AREAReplies: 11Last Post: 30th May 2009, 06:19 PM
