Results 16 to 30 of 36
Thread: Scraping problems
26th Aug 2018, 08:29 PM #16
I must admit, my control of the scraper tool isn't consistent . my scrape marks are not geometrically neat. Yes, am stoning between scrapes. Will post more pics tmw.
27th Aug 2018, 12:35 PM #17
This piece of iron was relatively flat before I did the scraping . I'm still struggling with placing the scraped lines in line next to each other , my strokes tend to wander all over the place , a lack of control
27th Aug 2018, 02:43 PM #18Most Valued Member
Do you change your scrapeing direction each cycle as in scrape in one direction, blue up and then scrape at 90 degrees to previous direction? If not then you will end up with hollows.
Looking at your scrapeing pattern, it does look a little erratic.
After a few cycles you should have more of a consistent cross hatch of scraper marks.
Edit: some of your scrapeing marks look really long, almost like frosting but this is usually done at the end, if at all.
27th Aug 2018, 04:54 PM #19Most Valued Member
- Jul 2016
- 35
- 1,522
I think not long ago tom lipton posted some videos using water based artists paint as a substitute for dykem hi-spot, looked like a good alternative to me!
27th Aug 2018, 05:19 PM #20Pink 10EE owner
- 6,218
Push the scraper with your body not your hands.
These videos of people using a scraper with a file type handle, it is a wonder they get any material off.Gold, the colour of choice for the discerning person.
27th Aug 2018, 08:03 PM #21
Is there any reason why the scraper shank is so long ? Seems excessively long but I guess that's why RC said to use ur body , not hand. Might try a larger radius , 80 mm .
27th Aug 2018, 11:33 PM #22Golden Member
- Nov 2010
- Gippsland Victoria
- 733
Did anybody ever write down and summarise the stuff we learned while doing the scraper courses with Machtool a few years ago - there are various threads about the courses and various websites / videos listed in those threads which may be worth a trawl through.
28th Aug 2018, 12:44 PM #23
This guys scraping makes my effort look brilliant
https://www.youtube.com/watch?v=WzK3kgv_n3k
28th Aug 2018, 01:34 PM #24
This is interesting but he does talk a lot rather than show how to do stuff. Note the reference to aqua wash'' that he uses as the spotting dye.
https://www.youtube.com/watch?v=QUtH...tu.be&t=36m35s
28th Aug 2018, 02:24 PM #25Most Valued Member
2nd Sep 2018, 08:09 PM #26
Chattering
Now I'm having issues with the tool chattering. The blade edge is slightly rough , looking at it with the x50 loupe .
3rd Sep 2018, 07:47 PM #27
Getting more consistent results now, I found that I had too much blue on the plate.
4th Sep 2018, 01:55 PM #28
OK things are looking better. Stefan G didn't mention an important and necessary tip in his utube blurb: I have found by trial and lots of error , that it's important to hone the blade edge . After hand polishing the blade edge over the 3000 grit diamond , the edge is now looking much better and it now scrapes without chattering. Now I need to practice more .
4th Sep 2018, 06:54 PM #29Most Valued Member
- 2,672
Not sure which of his scraping videos you've watched, but if you go to 10:30 in this one he talks about the 3000grit diamond he's got on his grinder and shows how he sharpens.
https://www.youtube.com/watch?v=S9N3Q8Qww2A
4th Sep 2018, 09:42 PM #30
Will there be another scraping class?
By snapatap in forum METALWORK GENERALReplies: 421Last Post: 15th Jun 2015, 07:13 PM -
For the scraping Class
By DSEL74 in forum METALWORK GENERALReplies: 5Last Post: 27th Nov 2014, 02:23 PM -
New Scraping Project
By scottyd in forum METALWORK GENERALReplies: 11Last Post: 21st Oct 2014, 11:29 PM -
Scraping
By raypat in forum METALWORK GENERALReplies: 2Last Post: 6th Nov 2012, 09:25 PM -
Swiss Scraping or scraping from the shoulder
By Ueee in forum METALWORK GENERALReplies: 3Last Post: 30th Jul 2012, 01:31 AM
