Results 1 to 15 of 16
Thread: Slotting Head As Filer?
23rd Aug 2018, 06:48 PM #1.
- 6,459
I have a small project where I would like to cut a 12 x 12mm square hole through a 22mm thick piece of 4E cast iron. My initial plan was to grind a 1/4" square piece of HSS into the shape of a slotting tool and use it in the pretend slotting head I made years ago for my little Hercus mill. Without the presence of coolant the HSS has turned numerous shades of purple and I have worn away a lot of my cup wheel so I have pretty much abandoned the slotting idea.
The current idea is to use a cut down file in the slotting head. I will need to make some sort of keyed backing piece for the file to avoid the possibility of bending the file with the toolpost's clamping screw. The file pictured, an English Stubbs in good nick, won't be the donor for modification. Die filers usually have their files clamped top and bottom but I'm thinking that if I used a file about 3/8" square I might have enough rigidity.
Has anyone tried something like this?
BT
23rd Aug 2018, 06:56 PM #2
Hi Bob,
Yes that idea will work fine. I would arrange a roller, under the table, use a ball race wrapped in masking tape, or a hard rubber faced one behind to support the file.
I made a similar arrangement using a drill stand and a chisel to cut some timber joints with square faces.Best Regards:
23rd Aug 2018, 07:06 PM #3Philomath in training
Last time I had to do a square hole in some steel (might have been 19mm square?) I drilled it out I think with something like 3mm holes in the corner of the square and then just under the full diameter in the centre. Doing it that way, it did not take long at all just to dress the sides with a square file.
Especially for a piece of CI, you may be doing more work on your set up than you need to.
(PS - it was the 36 handle...)
23rd Aug 2018, 07:09 PM #4.
- 6,459
The roller makes sense John. My concern is the amount of Z I have, the ever present issue with both mills!
23rd Aug 2018, 07:43 PM #5
Whilst Michael is right, it wouldn't take a lot to do it by hand with a file, once you have removed the bulk of material ! There would be more fun setting up the slotter.
Bob, you only need about twice the material thickness of file movement.
What you really need is one of these:
14-08-2018-009.JPGBest Regards:
23rd Aug 2018, 09:46 PM #6Banned
- Jan 2018
- Aldinga Beach.
- 73
- 148
How do you keep all your machinery looking so nice and new, damned annoying that. Bet you'd like a filing machine, I know I would. I wonder if I could convert a reciprocating saw???
23rd Aug 2018, 10:10 PM #7Most Valued Member
Probably not much help, but at least it's on topic!
https://www.youtube.com/watch?v=6lxJ...&frags=pl%2CwnChris
23rd Aug 2018, 10:15 PM #8.
- 6,459
On,
The trick is to not use something. I made that slotting head back in 2009 and I'm still trying to find a use for it. The rest of the stuff is just careful photography. As to wanting a filing machine, well if the slotter does the job I won't be looking any further.
Bob.
24th Aug 2018, 12:04 AM #9Golden Member
- Jul 2011
- 837
Sitting smugly here in Adelaide with my locally made Steelfast filing machine at the ready.
24th Aug 2018, 12:01 PM #10Most Valued Member
- Australia east coast
- 2,713
24th Aug 2018, 12:19 PM #11.
- 6,459
24th Aug 2018, 12:46 PM #12Most Valued Member
- Jul 2016
- 35
- 1,522
With the slotting, what depth of cut were you using, did you cut on more than one facet of the tool simuntainiously? I find with my filing machine I need to avoid cutting on two faces of square files.
24th Aug 2018, 03:44 PM #13Most Valued Member
- 2,713
Yeah good question - I've got mine geared down running through a 90 rpm planetary g/box to dual A section belts with maybe 3:1 further reduction. It does stall on a too aggressive DOC - well the belts slip.
I've successfully nibbled out a 20mm internal keyway in A36 steel, 120mm deep, but it was painfully slow. Right on the limits of that slotter I'd say. If I ever have to do another it's going on the planer (assuming I have it running again when I need it).
PDW
31st Aug 2018, 08:34 PM #14.
- 6,459
It Worked, Nicely
I marked the cast iron bar out on both sides so I had the ability to check if the filing was square to the face of the bar.
I drilled a 15/32" clearance hole and commenced filing with a brand new Nicholson square bastard file but found that the corner radius of the file was larger that I needed. I then used a second hand four dollar Stubbs second cut square file that while worn, cut in an easily controllable manner.
The problem I had with my initial set up using the angle plate was that I could not remove the cast iron bar without removing the file. With the file cut in half with a Dremel and the angle plate replaced with the mill's vice, checking for size became easier. The file cut square front and back because it was held square on the ram's tool mount. Sideways it cut a slight taper either through deflection or sloppy mounting of the file, either way it was easily remedied with a touch of hand filing.
DSC_9905 (Large).jpg DSC_9906 (Large).jpg DSC_9909 (Large).jpg DSC_9912 (Large).jpg IMG_20180831_142946298 (Large).jpg
I have never used a die filer so I am unable to draw comparisons but using the mill allowed me to utilise the table's micrometer feeds. I was able to work up to the scribed lines and corners with a reasonable degree of accuracy. A bit more accurate than hand filing in my bench vice. The stroke speed was not an issue.
Bob.
1st Sep 2018, 05:08 AM #15
Nice one Bob, Just shows, there is more than one way to skin a rabbit.
For Sale Vic. Bridgeport Mill with Slotting Head.
By Machtool in forum METALWORK - Machinery, Equipment, MARKETReplies: 11Last Post: 29th Nov 2016, 09:15 PM -
Die Filer Clamp
By DSEL74 in forum METALWORK GENERALReplies: 3Last Post: 14th Sep 2015, 12:55 AM -
Slotting Tools
By wbleeker in forum METALWORK GENERALReplies: 4Last Post: 11th Apr 2015, 06:35 PM -
Slotting machine on auction
By Briangoldcoast in forum METALWORK GENERALReplies: 1Last Post: 18th Feb 2014, 02:54 PM -
Slotting - A Rough Attempt
By Anorak Bob in forum METALWORK GENERALReplies: 33Last Post: 8th Jan 2011, 06:13 PM
