Results 1 to 15 of 20
Thread: Countersunk socket head screws
21st Aug 2018, 12:15 PM #1Most Valued Member
- 4,255
went to order some UNC 5/16 CS sh screws and asked for a countersink as well..yep no problems they say.
I ask if its 82 degree...countersales says no its 90? they didnt know that UNC was 82 until I pointed him to unbrako page..never been asked for one..records show they have never sold one... how can they sell UNC CS SH screws and have no idea..this is reputable nuts n bolts outlet. What have all others customers been doing when they buy UNC CS? even > than 20mm metric changes to some other obscure angle..60?
what does every one else do?...any links to reasonably priced 82...
best I could source from non online wanted a kidney as well as my wallet.
21st Aug 2018, 12:36 PM #2Most Valued Member
- 4,887
If you have the room in the material can you just counter sink deeper to get the head below the surface,angle would not be correct but may work, otherwise grind a drill to suit.
21st Aug 2018, 01:16 PM #3Most Valued Member
- 4,255
21st Aug 2018, 01:45 PM #4Most Valued Member
- 4,887
That's unfortunate.
21st Aug 2018, 01:56 PM #5Senior Member
- Dec 2013
- 201
Can you use the drill sharpener to re-grind the csk heads?
Graham.
21st Aug 2018, 04:48 PM #6China
- Dec 2005
- South Australia
- 1,656
https://www.unitedfasteners.com.au/ you could try this mob
21st Aug 2018, 08:17 PM #7.
- 6,458
Hi Richard,
Cheap 82 degree countersinks are available but whether they are any good is another question - https://www.ebay.com.au/itm/2Pcs-1-2...0AAOSwubFaeXd-
A single Weldon bit may not be too prohibitively expensive if you have a Shipito account - https://www.ebay.com/itm/Weldon-CS-1...-/202135251705
Bob.
21st Aug 2018, 08:21 PM #8Most Valued Member
- 4,255
21st Aug 2018, 08:22 PM #9Most Valued Member
- 4,255
21st Aug 2018, 08:31 PM #10Most Valued Member
- 4,255
I did question those too Bob...sound too cheap to be hss
can still get one from usa if I need to and it will still be cheaper than what General Tools and Teravin Tools here in adelaide quoted...both in excess of $95 with one being over the ton. I will keep looking.
to mod a drill and run the risk of totally stuffing it is not to my liking ...its about 19mm dia head in the cs screws
21st Aug 2018, 08:43 PM #11Most Valued Member
- 4,255
22nd Aug 2018, 02:44 AM #12
Hi Eskimo,
I was lucky and got a set of weldon countersinks and deburring cutters cheap. However it is not dificult to regrind a three flute 90 degree countersink to 82 degrees with the lathe and tool post mounted Dremel. You could do the same with a twist drill if you wanted to.
Or how about a spade bit ? You would have to make a holder, but the replacement blades aren’t to expensive, and they are carbide.
A Weldon countersink to do 20mm ain’t going to be cheap.Best Regards:
22nd Aug 2018, 08:44 AM #13Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Would a 'D' bit cope with the job? Easy to make with a lathe and mill.
Phil
22nd Aug 2018, 10:39 AM #14Most Valued Member
- 4,255
22nd Aug 2018, 11:17 AM #15Most Valued Member
- Australia east coast
- 2,713
Hardness of socket drive set screws
By Grahame Collins in forum METALWORK GENERALReplies: 25Last Post: 29th Nov 2016, 12:57 PM -
Flat head socket screws
By neksmerj in forum METALWORK GENERALReplies: 12Last Post: 11th Jun 2015, 11:12 PM -
small steel round head slotted wood screws #2, #3, & #4
By eskimo in forum METALWORK GENERALReplies: 28Last Post: 26th Nov 2013, 09:08 PM -
socket head screw sets? Where for decent price?
By desbromilow in forum METALWORK GENERALReplies: 9Last Post: 24th Nov 2012, 07:34 AM -
countersunk aluminium plate what is the best way?
By thorens in forum METALWORK GENERALReplies: 6Last Post: 24th Aug 2012, 05:15 PM
