Results 16 to 29 of 29
Thread: Waldown drill.
21st Aug 2018, 06:31 PM #16Diamond Member
- Aug 2006
- 1,106
Yeah i'm with the others here, it would be an add on, you can unbolt it. Go take another look at it and maybe bring a shifter with you so you can unbolt it and take it off
21st Aug 2018, 06:44 PM #17Banned
- Jan 2018
- Aldinga Beach.
- 73
- 148
Ahhh, I get it , all this time I thought the headstock was part of my lathe, now I know better, it's bolted on therefore it must be an add on. Now that I look at it, the table is also bolted on, so that would also be an add on. Then there's the base and the headstock.
Geez, you didn't get much for your money with a Waldown drill press, just a column, then you had to buy all the ad on bits.
21st Aug 2018, 07:04 PM #18Diamond Member
- Aug 2006
- 1,106
They way you mentioned it before I thought you were saying it was part of the casting of the actual base.
21st Aug 2018, 07:15 PM #19Banned
- Jan 2018
- Aldinga Beach.
- 73
- 148
I may have but what I'm saying, part of or bolted, it looks to be a complete machine, just twirl the table around the back and instant access to the xy table. On the end of the two handled spindle there is a three cornered fixture which appeared similar to the knobs you pull out/push in to engage the vertical fine adjustment; but I couldn't budge it so maybe not, like I said the press looks a bit light on for milling work.
Having looked at the Waldown I'm happy I have a Taiwanese pedestal, at least mine has some meat to it, both in column size and vertical spindle size. I'd imagine there'd be a bit of wear and play there.
21st Aug 2018, 07:20 PM #20
Is this the knob your talking about?
If so that locks the depth gauge.…..Live a Quiet Life & Work with your Hands
21st Aug 2018, 07:35 PM #21Diamond Member
- Aug 2006
- 1,106
Even the colour of it doesn't match the drill press. That x - y table was probably used for a specific job where the need to adjust the height wasn't needed. Could have had a vice on there as will which would have helped with the height too. Base most likely drilled to suit the two bolts of x - y table.
22nd Aug 2018, 08:19 AM #22Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Nope the xy table was bolted on
I make it that base is original and the x/y table has been bolted on to do a specific job at that height.
Years ago I operated an old Macson lathe that had an MG gearbox bolted to it but I would never deduce that MG would design a gearbox with a lathe attached to it.
I am one 100% certain that nobody is having a go at you but when you state emphatically that the x/y table was cast as part of the base and it clearly isn't, members are going to point it out.
In all honesty, nobody is having a go at you and I fully understand that I shouldn't have made a crack about the Macson lathe but...
a semi tongue in cheek,
Phil
22nd Aug 2018, 10:48 AM #23
Original waldown base.
22nd Aug 2018, 10:49 AM #24Most Valued Member
- 4,258
One of my Waldown's has some very strategic placed tapered holes in the table, even having a locating pin to pin the table to the support, obviously done to ensure the table stays at 90 to spindle...I guess that going by onanonanon's theory it must be original eh? even tho the other 4 Waldowns i own dont have them.
22nd Aug 2018, 11:36 AM #25Banned
- Jan 2018
- Aldinga Beach.
- 73
- 148
My theory is based on what I saw, not arrogance!
22nd Aug 2018, 08:10 PM #26Most Valued Member
- 4,258
Well it does not by the photos submitted by yourself prove or even show that the xy table could seriously be considered as being original. The diy belt guard gives some indication as to its age....ie it did not have one when it was manufactured. Did they really have chinese made xy bolt on tables back then?
22nd Aug 2018, 09:24 PM #27Banned
- Jan 2018
- Aldinga Beach.
- 73
- 148
I don't know what that has anything to do with anything, but yep, that pretty well sums you up, not that I would expect anything else though.
Anyway, you have your views and I have mine, I'll leave it with you lot, I'm sure you'll enjoy yourselves!
22nd Aug 2018, 09:27 PM #28Golden Member
- Jul 2011
- 837
24th Aug 2018, 10:52 AM #29Most Valued Member
- 4,258
What's the fuss about a Waldown drill
By Michael G in forum METALWORK GENERALReplies: 38Last Post: 19th May 2021, 06:21 PM -
Waldown Drill - odd thread??
By Gavin Newman in forum METALWORK GENERALReplies: 3Last Post: 2nd Apr 2017, 04:46 PM -
WTB: Base for Waldown drill
By Com_VC in forum WANTED TO BUYReplies: 4Last Post: 1st Nov 2016, 10:31 PM -
Identifying an old Waldown Drill
By DSEL74 in forum METALWORK GENERALReplies: 25Last Post: 24th Nov 2014, 02:44 PM -
Waldown Drill Press
By KevM in forum METALWORK GENERALReplies: 24Last Post: 1st Sep 2011, 01:31 AM
