Results 31 to 44 of 44
26th Aug 2018, 06:21 PM #31Golden Member
- Jul 2011
- 837
A small issue resolved
When I took this grinder apart I found that I hadn't been the first to try. The centrifical start winding switch was damaged with the phenolic plate being fractured around its mounting holes.
So todays job was to remake it with a couple of pieces of modern fibreglass printed circuit board material replacing the pieces of phenolic sheet.
The finished piece is actually not too bad and I am hoping for another 70 years of operation from it.
26th Aug 2018, 07:50 PM #32
That is a neat repair and is exactly what I would have done ! Did you make sure that the contacts were clean before you re-assembled it.
Earlier I recall some one saying something about converting it to delta ??? I thought this was a single phase induction motor.
At least that is what it said on the rating plate.Best Regards:
26th Aug 2018, 08:00 PM #33Most Valued Member
- Charlestown NSW
- 1,673
Baron.
These grinders were available in both single and three phase. Identical to look at. I think the single phase bring more money used though.
peter
26th Aug 2018, 08:05 PM #34Member: Blue and white apron brigade
26th Aug 2018, 09:45 PM #35Golden Member
- Jul 2011
- 837
26th Aug 2018, 10:25 PM #36Most Valued Member
It'll last longer than 70 years, as long as some ham fisted clown leaves it alone.
27th Aug 2018, 01:28 AM #37Golden Member
- Jul 2011
- 837
It has a cover that bolts over this set of terminals, with the cover is removed it becomes obvious that order of disassembly is important. This repair was only necessary because some clown had tried to get in there. I don't think they did actually manage too because the bearings were still the original Hoffman made in England ones and there really is no reason for getting in there other than to change bearings.
28th Aug 2018, 10:50 PM #38Golden Member
- Jul 2011
- 837
A lucky match
I bought some Mid Brunswick Green Rustkill in a spray can and the match isn't so bad. In the photo the base is the new paint and the bearing cover in my hand is in the original paint.
1st Sep 2018, 11:32 PM #39Senior Member
- Perth, Western Australia
- 67
- 362
While reading this thread the other day a faint memory popped into my head, so I went and had a look.
Yep, after cleaning the plate it said GMF. I have had for over 20 years and it`s been faultless. Takes all my abuse.
26th Sep 2018, 12:01 AM #40Golden Member
- Jul 2011
- 837
Waiting on wheels
Supposedly my wheels will arrive tomorrow and this will be finished. Except for a detail, where do I buy 2 drive pins from to reaffix the id plate?
Before and after shots
26th Sep 2018, 07:51 AM #41
Great job on the resto.
I would give my eye teeth for one of those.
If you mean these
They are referred to as hammer drive screws and you may have to buy a box.
Most fastener shops should be able to get them.
26th Sep 2018, 08:48 AM #42Golden Member
- Jul 2011
- 837
26th Sep 2018, 09:09 AM #43Most Valued Member
- Charlestown NSW
- 1,673
You are not going to use it now are you? It looks far too pretty for that. Nice job. Puts my old one to shame.
peter
26th Sep 2018, 07:39 PM #44Golden Member
- Jul 2011
- 837
IMG_20180926_160105.jpgIMG_20180926_160346.jpgIMG_20180926_160041.jpgIMG_20180926_160341.jpg
FInally finished. I should have taken the photos before I dressed the wheels. Now I can move on to my next project which is my shed ceiling.
Hercus T&C Grinder accessory identification.
By lamestllama in forum THE HERCUS AREAReplies: 10Last Post: 21st Oct 2017, 09:51 AM -
Bench grinder advice
By brendanh in forum METALWORK GENERALReplies: 23Last Post: 20th May 2015, 11:46 PM -
bench top for a bench grinder
By wodstok in forum METALWORK GENERALReplies: 1Last Post: 24th Jan 2011, 03:04 PM -
Bench grinder question
By mic-d in forum METALWORK GENERALReplies: 2Last Post: 30th Nov 2010, 06:33 PM -
Which 200 mm bench grinder should I buy ?
By Retromilling in forum METALWORK GENERALReplies: 15Last Post: 16th Oct 2008, 11:31 AM
