Results 16 to 30 of 44
21st Aug 2018, 06:48 PM #16Most Valued Member
- Charlestown NSW
- 1,673
Eric
So what was the original colour of yours?
peter
21st Aug 2018, 06:53 PM #17Banned
- Jan 2018
- Aldinga Beach.
- 73
- 148
There must have been a few models of the GMF BG, I have an oldish one I bought in 1976, it didn't have the table securing post through the base though.
21st Aug 2018, 07:59 PM #18.
- 6,459
IMG_20180821_163844925_BURST000_COVER_TOP (Large).jpg IMG_20180821_163824065 (Large).jpg
McPherson's 1960 catalogue shows the round motor housing as per China's photo.
BT
22nd Aug 2018, 10:04 AM #19Golden Member
- Jul 2011
- 837
Bob,
Thank you for the scan from the McPhersons catalogue.
The grinder with the Douglas attachment looks exactly like mine (which is an 8") except for the switch which on mine has a pressed metal shelter over it with GMF embossed in it. Otherwise all the small details are identical so I am supposing my grinder is from around that period. The serial number is F54555 which might give an indication of date too.
Eric
22nd Aug 2018, 07:58 PM #20Golden Member
- Jul 2011
- 837
Today I stripped this apart and took everything but the casting with the stator in it to be sandblasted. The original green paint seems to be a good match for rustkill mid brunswick green which suits me.
22nd Aug 2018, 10:31 PM #21Golden Member
- Jul 2011
- 837
IMG_20180822_085154.jpgI cleaned the thick black paint of the plate it seems that the low areas of this plate where filled with red except around the GMF logo which was black. Unfortunately that wasn't saveable and the poor grinder will have to make do with a brass plate.
23rd Aug 2018, 09:54 AM #22Member: Blue and white apron brigade
Just thinking 1/2HP might be a bit light for 8" wheels and may work better with 6"?
FWIW here are my two 1HP 8" GMFs (before I tidied up the wiring)
The gold one now has a green wheel on the RHS shaft.
23rd Aug 2018, 08:22 PM #23Most Valued Member
- Charlestown NSW
- 1,673
24th Aug 2018, 12:12 AM #24Golden Member
- Jul 2011
- 837
That brace of grinders looks very pretty.
I have no idea how good 1/2hp will be on the grinder as I didn't use it before I pulled it apart. Now its too advanced to stop until its finished.
I picked up the bits from the sandblaster but ran out of primer before I finished coating them today. Hopefully i will have some new bearings tomorrow.
24th Aug 2018, 08:13 AM #25
Hi lamestllama,
If your GMF is like all the other GMF bench grinders I have encountered in my time spent in educational training institutions, it will be nothing less than brilliant.
They are certainly far better than anything readily available today.
The fact that the machine will spin on for some minutes after shut down is an indicator of how well they were designed and manufactured. If there is a better class of bench grinder available here in Oz ,well, I am yet to encounter it. To me GMF grinders are the Rolls Royce of the industry.
25th Aug 2018, 11:37 AM #26Golden Member
- Jul 2011
- 837
IMG_20180824_153556.jpgSome progress. Epoxy primer then epoxy filler over the places with voids in the castings.
25th Aug 2018, 11:51 AM #27Golden Member
- Jul 2011
- 837
25th Aug 2018, 07:59 PM #28Most Valued Member
- Charlestown NSW
- 1,673
Eric
Thanks for that. That is actually not much different from the green enamel I painted mine with back in the late 1970's. I must have fluked it at the time as I only used some green paint that my Dad had.
peter
25th Aug 2018, 08:43 PM #29Golden Member
- Jul 2011
- 837
26th Aug 2018, 09:30 AM #30Member: Blue and white apron brigade
Hercus T&C Grinder accessory identification.
By lamestllama in forum THE HERCUS AREAReplies: 10Last Post: 21st Oct 2017, 09:51 AM -
Bench grinder advice
By brendanh in forum METALWORK GENERALReplies: 23Last Post: 20th May 2015, 11:46 PM -
bench top for a bench grinder
By wodstok in forum METALWORK GENERALReplies: 1Last Post: 24th Jan 2011, 03:04 PM -
Bench grinder question
By mic-d in forum METALWORK GENERALReplies: 2Last Post: 30th Nov 2010, 06:33 PM -
Which 200 mm bench grinder should I buy ?
By Retromilling in forum METALWORK GENERALReplies: 15Last Post: 16th Oct 2008, 11:31 AM
