Results 1 to 6 of 6
Thread: End Mill Recommendations
16th Aug 2018, 06:04 PM #1Golden Member
- Apr 2008
- Canberra
- 805
Hi All,
Just got a new milling machine and am looking for some recommendations on what sort and size end mills to buy. I will mostly be making project in mild steel and maybe occassionally stainless. Upcoming projects will be making QCTP holders for the lathe, a toolpost grinder, ball turner, carbide tools etc.
I am pretty green when it comes to milling and not sure if I should get 2 flute, 4 flute, ball nose, hss, carbide etc. Also if any stores can be recommended that would be good too - I used to buy a lot of lathe tooling from CTC tools which I liked but these days I notice that Bang Good seem to be popular however I dont know how their quality compares.
My machines a big rigid machine with spindle speeds up to 1800rpm if that helps. Further info here:
//metalworkforums.com/f65/t2021...machine-poland
Brendan
16th Aug 2018, 08:55 PM #2
Around 1800rpm is down in lower end for smaller diameter carbide tipped cutter's as it likes to spin fast, but will still work.
I'd be going a large face mill like 150mm with 6 tips if your shed power supply is up to it. This will get your surface speed up.
I followed the link, really nice mill, congratulations.
Hss is a bit of hit and miss with the cheaper ones. You can get great or crap, steer away from AL advertised, it's for soft metal like aluminum mild steel (with coolant).Using Tapatalk
16th Aug 2018, 09:05 PM #3Golden Member
- Apr 2008
- Canberra
- 805
Thanks Dave. What about solid carbide end mills? Do they need heaps of RPM? It came with a 75mm face mill which is pretty good. It’s a sandvik one. I want to get a bigger one to work on cylinder heads
16th Aug 2018, 09:50 PM #4
Here is a good little chart I found many years ago, It gives you a good ballpark figure to aim for, I have it taped to a cupboard in the shed.
Using Tapatalk
16th Aug 2018, 11:23 PM #5Gear expert in training
- 34
- 1,075
I've always recommended Carbitool on the woodwork forum, they make a whole range for metalwork as well and they're Australian made, which is nice.
17th Aug 2018, 07:14 PM #6Golden Member
- Apr 2008
- Canberra
- 805
Thanks mate, I’ll check them out !
Plasma Cutter Recommendations
By RayG in forum WELDINGReplies: 10Last Post: 23rd Mar 2013, 12:33 PM -
Thoughts, Recommendations for low amp plasma gun
By Log in forum WELDINGReplies: 2Last Post: 18th Mar 2012, 08:32 PM -
Current bandsaw recommendations
By WelderMick in forum METALWORK GENERALReplies: 65Last Post: 14th Aug 2011, 10:10 PM -
4 jaw chuck recommendations
By snowyskiesau in forum METALWORK GENERALReplies: 39Last Post: 7th Oct 2008, 06:11 PM -
RHS tube bender.... any recommendations ?
By Fossil in forum METALWORK GENERALReplies: 9Last Post: 22nd Jan 2008, 12:19 PM
