Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 63
  1. #46
    7,188
    Quote Originally Posted by Mdouble View Post
    It looks like my collet adapters are machined at a slightly incorrect angle (unluckily I got 2 from separate suppliers) and wont seat the collets correctly.
    Just checking, by "collet adapters" do you mean "collet chuck"?
  2. #47
    Jun 2016
    Sydney
    283
    Could you let us know who was the supplier - so we don't go there!
    If 2 different eBay suppliers, one suspects they were just 'retailers' with the same source.
  3. #48
    Jun 2012
    SA
    1,649
    Can anyone recommend a supplier with a reasonably priced accurate collet set?
    Thanks everyone for your help
    CTC Tools. They only sell DIN standard collets/sets. I got all mine there. No problem.
    There are a lot of non DIN collets/sets being sold on Ebay, Banggood etc. Not worth the risk.
    The worst that can happen is you will fail.
    But at least you tried.
  4. #49
    7,188
    Quote Originally Posted by nearnexus View Post
    I haven't used mine much but I will second that.
  5. #50
    Aug 2018
    Tasmania
    48
    19
    Yes, the collet chuck. I originally called it a chuck, but it was referred to as an adapter by another user so I thought I'd better stick to that terminology to reduce confusion .
  6. #51
    Aug 2018
    Tasmania
    48
    19
    Quote Originally Posted by rcaffin View Post
    They were generic ones off ebay (and look almost identical).
    When I bought the collet set, it arrived without a spanner. I argued with the seller, but they insisted it didn't come with one. I decided to buy another chuck (with spanner) instead of just buying the spanner, so I'd have 2 chucks for different tooling set up.
    Mat
  7. #52
    May 2011
    Murray Bridge S Aust.
    5,959
    If you have access to a metal lathe, you could set up a grinder to grind the collet chuck to the correct angle, saves buying a replacement.
    If you don't want to do that, let me know and I'll buy them from you, as I love a challenge. Not that I'm set up for a challenge just yet.
  8. #53
    Aug 2018
    Tasmania
    48
    19
    I was thinking it trying that. It will be an interesting challenge. Although, I'm nowhere set up either
    Mat
  9. #54
    May 2011
    5,959
    You'll need a taper turning attachment for the lathe, they're fun to make. I visited someone a few weeks ago, and mentioned he'd been asked as to why so many machines, he said "it was to make parts for theat machine to make parts for that machine to make an accessory for that machine"
  10. #55
    Aug 2018
    Tasmania
    48
    19
    I was thinking of just using a small die grinder mounted on the compound. It's a short taper to grind.
    Mat
  11. #56
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Is the collet chuck hard,if not just machine the taper and then polish.
  12. #57
    Jun 2016
    Sydney
    283
    Yes, you could remachine the taper, or regrind it. Note that you must make it 8.00 degrees, not 7.9 or 8.1 degrees.
    I have bought a number of sets of collets from eBay. I did check they were to the DIN standard. In my (limited) experience, Chinese stuff when made to DIN spec seems to work OK. You will probably find that technical stuff like collets are being made on German CNC machines. They are industrialising fast.
    Roger
  13. #58
    Dec 2010
    Syd
    492
    I'm getting a malicious site warning from the isp at the moment for some reason, but I've bought er collets from ht-tools.net in the past and haven't had problems - a couple of bucks a pop. Is CTC still taking forever on orders?
  14. #59
    7,188
    Quote Originally Posted by Hunch View Post
    It varies - My last order took 2 weeks but the one before that took six weeks.
  15. #60
    Aug 2018
    Tasmania
    48
    19
    I had a little play tonight. I remember I bought a hex collet block (which the collets seem to fit in there much nicer than in my chucks).
    I set it up in the lathe with as little runout as possible. Then put the test indicator on the compound to dial in the angle (within 0.02mm or so). I then tried one of my ER chucks. I ended up with around 0.2mm on the indicator (I only had it mounted in the 3 jaw by the body of the chuck, but I turned the spindle and checked in multiple spots, with the error always in the same direction). A bit of confirmation is always nice.
    Mat.
  1. Preventing collet slip & tool holder torque
    By steran50 in forum METALWORK GENERAL
    Last Post: 8th May 2013, 02:57 PM
  2. Slitting Saw Runout
    By jack620 in forum METALWORK GENERAL
    Last Post: 23rd Mar 2013, 09:00 AM
  3. How To Avoid Cross Threading Bolts and Screws
    By mike48 in forum METALWORK GENERAL
    Last Post: 6th Dec 2012, 11:45 AM
  4. runout test
    Last Post: 15th Oct 2011, 09:28 PM
  5. TOS Chuck Runout
    Last Post: 7th Mar 2011, 03:01 PM
