Results 16 to 30 of 63
14th Aug 2018, 09:30 PM #16
Yes I agree !
Hold the collets up to the light and look through each slot for crud etc.Best Regards:
15th Aug 2018, 02:35 AM #17Senior Member
- Apr 2013
- Toowoomba Qld
- 401
The two pictures you have above showing the cutter you have the cutter too far into the collet. In those pics if you tighten it up the nose of the collet will be clamping on the flutes of the endmill and not on the round shank. That is a big no no and would be a big contributing factor.
15th Aug 2018, 08:08 AM #18Most Valued Member
I have the cheapest set of er collets i could find from a Chinese seller and ive never had a problem with them.
One thing i have learnt is that if the collet does not tighten firmly and positively from loose to tight (after take up) in 1/4 turn then theres something wrong. Either theres swarf in the way or the tool is not seated properly.
15th Aug 2018, 08:33 AM #19Novice
- Aug 2018
- Tasmania
- 48
- 19
15th Aug 2018, 08:36 AM #20Novice
- Aug 2018
- Tasmania
- 48
- 19
15th Aug 2018, 08:42 AM #21Senior Member
- Jun 2016
- 283
I can't push a 3mm dowel through either 2-3 or 3-4 ones.
Ahhh - really?
The 2-3 collet should be a neat fit on a 3 mm dowel, and should close down to 2 mm. The 3-4 should take a 4 mm dowel neatly and close down to 3 mm. If you cannot get a 3 mm dowel through either of them, then something is REALLY wrong.
With all due respect, you need to get someone else who has used collets a lot to look at the collets. I can't help feeling it is something really simple!
Roger
15th Aug 2018, 09:32 AM #22Most Valued Member
- Jun 2012
- SA
- 1,649
Judging by the poor machining on the collet chuck it made me wonder if the thread is bad, causing a loose fit with the nose cap.
The thread is actually very important/instrumental in pulling the front taper into position correctly. Any slop is bad news.The worst that can happen is you will fail.
But at least you tried.
15th Aug 2018, 10:36 AM #23Senior Member
- Jun 2016
- 283
I doubt that it is the thread: the primary reference surface is the long taper. The short steeper taper at the front comes next, but that is definitely secondary. Frankly, I suspect that the thread could be as rough as guts (well, almost) and the collet should still work.
15th Aug 2018, 11:11 AM #24Novice
- Aug 2018
- Tasmania
- 48
- 19
15th Aug 2018, 12:02 PM #25Senior Member
- Jun 2016
- 283
The HM47 comes with a #3 Morse taper. Morse taper is OK for a drill, but a seriously bad idea on a mill as it can vibrate loose and let the cutter and adapter fall out. OK, so they put a #3M to ER32 adapter in - which is a recommended accessory from H&F with that machine. So first remove the adapter and clean both it and the taper it goes into, replace and tighten up the pull rod with a serious spanner. Then check it for wobble and TIR.
I don't think the taper angle on the chuck is the same as the collet.
That would be almost unbelievable - unless it is not an ER32 holder. There are other sorts of collet systems, some of them not too distant, but I would find it hard to imagine that you would find an ER32 nut fitting onto one.
But, that is still worth exploring. Can you borrow a #3M to ER32 adapter from someone else and try fitting it to your machine? Can you try borrowing a single good ER32 collet from someone else and try fitting it?
It would be a sad story if the person selling the HM47 did so because he could not get cutters to fit stably himself, because somewhere back up the history a previous owner (or even the vendor) screwed up with the adapter. Highly unlikely imho, but something is screwy here.
Roger
15th Aug 2018, 12:29 PM #26Novice
- Aug 2018
- Tasmania
- 48
- 19
I have checked the runout on the inside taper of the adapter with the drawbar tight and found about 0.02mm runout.
I do appreciate all the feedback
Mat
15th Aug 2018, 01:44 PM #27Most Valued Member
- Healesville
- 2,129
If you have lathe? and have a length of ground stock to suit 1 of your collets, put the stock in your lathe and check and note the run out of the stock, now fit your collet/chuck to the stock in your lathe and check what run out you have, note the high spot and turn the collet chuck 180 deg and check it again.
You get an idea of whether or not to bin the collet chuck.
Cheers, shed
15th Aug 2018, 01:46 PM #28Most Valued Member
- Healesville
- 2,129
It could also be a batch of dodgey collets
15th Aug 2018, 02:46 PM #29Senior Member
- Jun 2016
- 283
I bought the machine new from hare and Forbes,
Aha. Are they anywhere near you? Can you take the problem - or at least the collets and the adapter, back to them for checking?
but I don't think it's a machine issue. I have other tooling (a carbide face cutter) that seems fine.
Yeah, but what is the fitting for the face cutter? Morse taper? If so, that tells you zero about the adapter.
Roger
15th Aug 2018, 03:09 PM #30
Hi Roger,
I really should re-read my posts more carefully
That should have read "I can't push a dowel through either 2-3 or 3-4 ones."
Sorry about that. I'm going to blame it on old age. I wasn't too happy about discovering the harrage on the inside edges. I've since checked and found that all my collets have some. Particularly the ER16 ones I use on my drill grinder.Best Regards:
Preventing collet slip & tool holder torque
By steran50 in forum METALWORK GENERALReplies: 15Last Post: 8th May 2013, 02:57 PM -
Slitting Saw Runout
By jack620 in forum METALWORK GENERALReplies: 37Last Post: 23rd Mar 2013, 09:00 AM -
How To Avoid Cross Threading Bolts and Screws
By mike48 in forum METALWORK GENERALReplies: 9Last Post: 6th Dec 2012, 11:45 AM -
runout test
By morrisman in forum METALWORK GENERALReplies: 20Last Post: 15th Oct 2011, 09:28 PM -
TOS Chuck Runout
By Anorak Bob in forum METALWORK GENERALReplies: 17Last Post: 7th Mar 2011, 03:01 PM
