Results 31 to 45 of 63
15th Aug 2018, 05:48 PM #31Most Valued Member
- 4,887
As you have said you have collets from different sauces and the same problem with both,either really bad luck or user error in my opinion.
15th Aug 2018, 06:06 PM #32Senior Member
- Jun 2016
- 283
It would be a real giggle if what you have is an #3 Morse to RDF adapter. As far as I can tell, they look similar from the outside but are NOT compatible.
(for a given interpretation of 'giggle')
Roger
15th Aug 2018, 08:24 PM #33Novice
- Aug 2018
- Tasmania
- 48
- 19
Not in Tasmania, I had it freighted from Melbourne. The collets and adapters were purchased online. .
Yeah, but what is the fitting for the face cutter? Morse taper? If so, that tells you zero about the adapter.
Maybe I was too cheap, but I didnt want to be spending $2-300 and getting the same stuff. It's difficult to tell who is just reselling the cheap stuff at a higher price.
15th Aug 2018, 09:00 PM #34Philomath in training
- 6,542
I'm in Burnie and can make a run to see you if you like and bring some of my (cheap) ER32 collets to compare. Only trouble is that I'm not free to do so until the weekend of the 1st/ 2nd of September.
If that helps,
15th Aug 2018, 09:52 PM #35Senior Member
- Jun 2016
- 283
It's either the collet adapter, collet or nut. The problem is I have multiples of them, and they all give me problems.
Just checking: do you have multiple #3M to ER adapters, or just one of them?
Perhaps Michael can sort it out. Or maybe someone else.
Failing that and all else, you could post the adapter, a couple of collets and nuts, to me in Sydney and I could compare the lot with my set (#3M to ER32) which fits into my lathe and works well. You cover the postage both ways, so not cheap: an act of desperation!
Roger
16th Aug 2018, 06:30 PM #36Novice
- Aug 2018
- Tasmania
- 48
- 19
Thanks Michael. I appreciate the offer, and I'll keep it in mind. For the moment, I'm thinking of checking the adapters in my lathe (as suggested). I'm thinking the angle may not be uniform along the length of the taper on the inside of the adapter. I can 'rock' the collet in the adapter until I get quite a bit of tension on the nut. My feeling is that I should be able to do that if the angle was correct (it should be tight pushed in, even taking into account the springiness of the collet).
Mat
16th Aug 2018, 06:40 PM #37Novice
- Aug 2018
- Tasmania
- 48
- 19
I have 2 adapters with nuts, and multiple collets (which is why it's perplexing). With that information it would be likely to be the machine, but I've measured the runout on the spindle then the collet adapter (which is minimal). I surmised that it was 'operator error' which is why I decide to make the post
Mat.
16th Aug 2018, 06:57 PM #38Most Valued Member
- Australia east coast
- 2,713
I have quite a bit of tooling for ER32 and will be back in Hobart next week. Might be a bit closer option - I can certainly check some of your collets for runout in a known good chuck/spindle combination. Don't have any MT3 milling machines (thank God) so can't check the collet chuck. Pretty sure even my baby lathe is MT4 or bigger.
PDW
16th Aug 2018, 09:20 PM #39Novice
- Aug 2018
- Tasmania
- 48
- 19
Ok. Just a silly question. Is it correct to use a 8mm end mill in an 8-7mm collet?
I just had a look at the collet in the adapter. Without a tool in the collet, I can push the collet in and it doesn't 'rock' in the adapter (as the collet compresses). If I put the 8mm end mill in the collet, I can't push the collet in enough by hand to stop it rocking (I don't think tightening the nut with compress the collet enough to match the angle of the adapter either).
Mat
16th Aug 2018, 09:55 PM #40Senior Member
- Jun 2016
- 283
Very much so.
The hole up the middle is machined to 8.0 mm. The collet can be compressed down to 7 mm, but it will not hold a 7 mm drill bit as well as it will hold an 8 mm bit. For anything under 6 mm I use a collet sized to the nearest 0.5 mm. So I have collets 1.0, 1.5, 2.0, 2.5, 3.0, 3.5 etc, to get the best fit.
Possibly so, but not significant.
I will assume that the 8 mm end mill has an 8.0 mm shank. However, I note that 5/16" is close. Best to mic the shank.
Yes, you do need to tighten the collet nut up, and this is usually a two-handed (or two spanner) job. Hand tightening is NOT enough. Just make sure the collet is flush at the front face first: ie properly clipped in.
Roger
16th Aug 2018, 10:18 PM #41Most Valued Member
- 5,945
Do you have access to a protractor, if so, I'd measure the angles of the collet and chuck to check that they correspond.
I've had collets of different length in ER25, which equals different angles.
16th Aug 2018, 10:45 PM #42Most Valued Member
- 4,887
16th Aug 2018, 10:57 PM #43Senior Member
- Jun 2016
- 283
Sorry to be blunt, but that is wrong. The ER half-angle is exactly 8 degrees, for all sizes.
That is according to Rego-Fix, who invented them.
Roger
16th Aug 2018, 11:20 PM #44Most Valued Member
- 5,945
I've had one that was different, here's the link to the post. I know they're "supposed" to be the same.
//metalworkforums.com/f65/t1921...ht=ER25+collet
17th Aug 2018, 05:47 PM #45Novice
- Aug 2018
- Tasmania
- 48
- 19
Well just an update.
I discussed my issue with a guy at work, and he happened to have an MT3 ER collet set. He bought it in for me to try. I noticed a small difference instantly without even fitting it. The collet doesn't 'rock' in the holder like mine without the nut. I tried my collets in his holder and mostly the same, maybe a little 'rocking'. I put the holder in the machine and tightened the nut a bit (I couldn't really tighten it well because there weren't any flats on the holder for some reason). I spun it up and it looked good. I checked runout at 0.03mm (quite a bit better than my 0.5mm plus).
It looks like my collet adapters are machined at a slightly incorrect angle (unluckily I got 2 from separate suppliers) and wont seat the collets correctly. Can anyone recommend a supplier with a reasonably priced accurate collet set?
Thanks everyone for your help
Preventing collet slip & tool holder torque
By steran50 in forum METALWORK GENERALReplies: 15Last Post: 8th May 2013, 02:57 PM -
Slitting Saw Runout
By jack620 in forum METALWORK GENERALReplies: 37Last Post: 23rd Mar 2013, 09:00 AM -
How To Avoid Cross Threading Bolts and Screws
By mike48 in forum METALWORK GENERALReplies: 9Last Post: 6th Dec 2012, 11:45 AM -
runout test
By morrisman in forum METALWORK GENERALReplies: 20Last Post: 15th Oct 2011, 09:28 PM -
TOS Chuck Runout
By Anorak Bob in forum METALWORK GENERALReplies: 17Last Post: 7th Mar 2011, 03:01 PM
