Results 16 to 18 of 18
Thread: Sheraton SG
13th Aug 2018, 11:22 PM #16Most Valued Member
Hi Mark,
None of the above, just happy to see me arrive OK. Dam mobile was playing up and couldn't be contacted.
14th Aug 2018, 08:39 PM #17Most Valued Member
- Charlestown NSW
- 1,673
14th Aug 2018, 09:44 PM #18
The shaft on the one that I'm working with at the moment is 3/8" (9.5 mm ) diameter and 40 mm long. For my application that is fine. The shaft at the fan end is much shorter at 12 mm long, also 3/8" diameter. Whilst not intended to be reversible, I've discovered that inside the terminal box, I can swap a pair of wires and make it run the other way. Both windings measure the same resistance, so reversing it shouldn't cause it to overheat.Best Regards:
Information on Sheraton
By TomW in forum METALWORK GENERALReplies: 3Last Post: 25th May 2014, 09:26 PM -
New (Old) Sheraton CUB Lathe
By Nozzle in forum METALWORK GENERALReplies: 23Last Post: 24th Aug 2012, 01:24 PM -
Sheraton CUB
By morrisman in forum METALWORK GENERALReplies: 0Last Post: 14th Dec 2011, 09:31 PM -
sheraton prices??
By danielhobby in forum THE HERCUS AREAReplies: 0Last Post: 25th Jul 2010, 01:37 AM -
Sheraton SSS lathes
By Aussie redback in forum METALWORK GENERALReplies: 5Last Post: 5th Jul 2005, 02:41 PM
