Results 1 to 4 of 4
Thread: lantaine lam-350 taiwanese lathe
8th Aug 2018, 08:22 PM #1Senior Member
- Jul 2014
- melbourne
- 110
hi i have a lantaine lam - 350 lathe , taiwanese made and made under many different names, hondon, himount ect
i need to replace the oil level sight glasses, they are o-ring sealed and push in
does anyone know the size i need, i don't want to pull them out to measure if i can help it as i might have to use the lathe to make them if i can't find any
so if any one knows the hole size please let me know
thanks all
8th Aug 2018, 08:37 PM #2
Why not approach it this way:
Siphon enough oil out to drop the level below the sight hole.
Remove the plug, measure and machine a new one if necessary.
Running the machine on the low side for a few minutes won't do it any harm .
Make sure the hole is covered while machining as any gearing will fling it in all directions.
8th Aug 2018, 09:24 PM #3Most Valued Member
- 4,887
Whilst Grahame's suggestion has merit I would suggest similar , go to the hardware or similar and get a couple of rubber bungs or similar and push these into the oil holes and then replace the oil removed if you need to make them.
Sent from my T85 using Tapatalk
8th Aug 2018, 09:27 PM #4Senior Member
- Jul 2014
- melbourne
- 110
thanks for the reply grahame i know i can pop one out and measure , but thought someone might know off hand the size as they are a very common lathe. or once were
i only want to drain the oil once if i can help it, not that they hold much oil .
bit of luck and some one may know if not i will do as you suggest , i think it may be 30mm
thanks damien
wanted Chuck backing plate to suit Lantaine 350/ McMillan 2inch x 8TPI
By kjbs in forum WANTED TO BUYReplies: 0Last Post: 26th Apr 2018, 05:01 AM -
Lantaine cross-slide overhaul
By TheNutter in forum METALWORK GENERALReplies: 3Last Post: 15th Mar 2016, 09:18 PM -
Taiwanese saws
By 4-6-4 in forum METALWORK GENERALReplies: 8Last Post: 2nd Aug 2012, 07:43 PM -
Taiwanese lathe
By rfurzer in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 22nd Jun 2010, 04:41 PM
