Results 1 to 5 of 5
6th Aug 2018, 10:39 AM #1Intermediate Member
- Apr 2017
- Geelong
- 27
Alternate to Collet chuck for Lathe
I'm about to do a prototype run and this is my first time having to do a batch of parts on my lathe,
I need to make a bunch of the same parts from 35mm stock, and Im hoping to do it with reasonable efficiency.
my 3 jaw chuck wont give me the consistent concentric holding i need, and the 4 jaw will take ages, in the past i have used a collet chuck for this however a ER chuck wont go out to 35mm, and the jacobs style setups are all going to cost 1000s,
As Im only dealing with a single diameter I thought there may be a old toomakers trick for making some type of adapter for the 3 jaw? for quick and repeatable work holding?
6th Aug 2018, 10:51 AM #2Golden Member
- Mar 2009
- 54
- 825
You can make your own single use collets for use in a standard three jaw chuck.
A good example is shown in this clip:
https://www.youtube.com/watch?v=gCUkJydSmdA
Greg.
6th Aug 2018, 12:59 PM #3Most Valued Member
- Sep 2011
- Ballarat
- 3,103
You could make up soft jaws for the three jaw chuck.
Phil
6th Aug 2018, 07:42 PM #4Most Valued Member
- Healesville
- 2,129
What sort of lathe and chuck do you have?
You could loosen (almost loose) your mounting plate/chuck bolts and with the 35 mm stock in the chuck and an indicator you might be able to get the stock to run true with some well placed taps on the chuck with a rawhide hammer.
If the chuck is too tight on the mounting you might have to skim off half the amount of runout that you have.
If you dont want to spend the time sorting out your chuck alignment Hare and Forbes sell Gator chucks, .0005" repeatability/runout max they reckon.
cheers, shed
6th Aug 2018, 07:51 PM #5Senior Member
- Victoria, Australia
- 114
You could all things being equal, fit a 3 jaw inside a 4 jaw. My 250mm 4 jaw is rarely removed. I use with Er collet holders and 125mm 3 jaw. Alternatively a three jaw with two piece jaws can be modified into soft jaws.
ER40 Collet Chuck for Lathe
By Oldneweng in forum METALWORK PROJECTSReplies: 12Last Post: 31st Jan 2016, 04:53 PM -
Hare and Forbes 5C Collet Chuck for Lathe
By tbonesmith in forum METALWORK GENERALReplies: 13Last Post: 23rd May 2015, 08:33 PM -
Collet Chuck for the Lathe
By Oldneweng in forum METALWORK GENERALReplies: 35Last Post: 15th Jan 2015, 10:54 PM -
ER40 Collet Chuck for a lathe.
By aametalmaster in forum METALWORK GENERALReplies: 2Last Post: 6th Jun 2011, 08:29 PM -
Lathe collet chuck.
By .RC. in forum METALWORK GENERALReplies: 8Last Post: 25th Feb 2010, 11:43 AM
