Results 1 to 10 of 10
Thread: Mitutoyo Vernier Repair?
4th Aug 2018, 12:25 PM #1
I have a H&F digital caliber that is wildly inaccurate but “working”.
I also have these which a “helper” in my shed dropped to the floor. There is no visible damage but something has happened to the gear and track inside and they now don’t move.
Can you get them repaired/serviced and is it viable cost wise compared to replacement?…..Live a Quiet Life & Work with your Hands
4th Aug 2018, 02:12 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
I would take it apart and have a good look at everything, I have fixed a number of dti's just look carefully and take some photos so you can reassemble it.
You can get dial calipers of gumtree pretty regularly for under $60, no way a professional will repair it for less.
4th Aug 2018, 02:40 PM #3
I had a look into how to disassemble them online.
My concerns there are. New parts needed, further damage ie the tension spring.
I prefer this older style to the new plates bidy ones.…..Live a Quiet Life & Work with your Hands
4th Aug 2018, 04:26 PM #4Philomath in training
I've fixed them before. Similar sort of issue. The parts several years ago were around $80. Mitutoyo is a quality brand and worth doing if they are what you want, but there certainly are cheaper alternatives out there.
8th Aug 2018, 12:37 PM #5
$80 for a part for some calipers worth $120-130 new replacement seems a silly way to go.
Any recommendations brands for CHEAPER ALTENATIVE brands of either dial or digital callipers?
Is the Hare & Forbes Measuremax lines worthwhile?…..Live a Quiet Life & Work with your Hands
8th Aug 2018, 01:18 PM #6Member: Blue and white apron brigade
One thing I have come to realize over the last couple of decades of using digital callipers is to avoid those that attach the thumbwheel adjuster using a plastic parts as they eventually break.
Last year I bought this cheap set (the 150 and 300mm) of digital callipers and I am pretty happy with them for the level of work I do.
https://www.ebay.com.au/itm/150-200-...from=R40&rt=nc
When I was working we bought a selection of callipers for trial use by students and we were very impressed with the accuracy of even the cheapest callipers even after a years worth of student use. We eventually kitted out several labs and the the "take home experiments in a suitcase" with dozens of these callipers and they stood up to the student punishment reasonably well. They are of course not appropriate if you want certified accuracy
8th Aug 2018, 05:58 PM #7Senior Member
- Jul 2007
- 332
Just to add another perspective, I got a free set of digital calipers with a reasonable sized order from an Australian supplier, when they arrived the movement felt like it had just come out of the cement mixer, so a look see was undertaken, the photos would seem to tell most of the story, the resistance welded depth rod just fell off and the angle grinder completed the fit and finish. The box was ok though.
Would be best if buying other than known quality brands, try before you buy, or have a good return policy.
8th Aug 2018, 06:22 PM #8Most Valued Member
- Healesville
- 2,129
This is my favorite dig caliper https://www.ebay.com.au/itm/iGaging-...from=R40&rt=nc
I like the big screen and you could have 4 or 5 of these igauging calipers for the price of 1 mitty.
cheers, shed
8th Aug 2018, 10:08 PM #9Philomath in training
I guess it's horses for courses a bit here. I would
happilypay $80 to repair those calipers because a new set would cost lots more than that and the end result would be a reliable measuring tool.
Over the years I've bought some 'cheap' gear and sooner or later find that it really does not cut it - I had some digital calipers that drank batteries; a sliding protractor that felt like it was full of sand; another digital caliper that would dramatically change its reading just with a little extra pressure on the jaw and a micrometer that was stiff enough that you were never sure whether it was against the part or had just jammed.
Mitutoyo is a recognised brand in metrology because it is accurate, repeatable and precise, and consistently so. Take any of those 4 elements out and the gear will be cheaper but can you rely on what it tells you?
8th Aug 2018, 11:09 PM #10Most Valued Member
- Healesville
- 2,129
I use a digital caliper for rough measurements and almost never use them when machining to a finish, so no I don't rely on them, not even a mity.
Here is a comparison that a bloke has done with seven different digi calipers including a mitutoyo and the iGaging.
https://www.youtube.com/watch?v=n2lza0RZII8
cheers, shed
oops, this link here https://www.youtube.com/watch?v=1yqZx_FNbSs
Cheap vernier callipers
By BobL in forum METALWORK GENERALReplies: 8Last Post: 6th Aug 2017, 10:30 AM -
Vernier Calliper vs Micrometer
By DSEL74 in forum METALWORK GENERALReplies: 19Last Post: 20th Mar 2014, 03:03 PM -
Shipping damage and its repair on a Mitutoyo Optical Comparator's Protractor Screen.
By Anorak Bob in forum METALWORK GENERALReplies: 10Last Post: 24th Dec 2013, 12:42 PM -
A Very Early Vernier Calliper
By Ropetangler in forum METALWORK GENERALReplies: 6Last Post: 29th Jan 2013, 09:28 PM -
vernier query
By morrisman in forum METALWORK GENERALReplies: 9Last Post: 28th Nov 2012, 12:37 AM
