Results 16 to 19 of 19
Thread: flattening hot rolled plate
4th Aug 2018, 09:39 PM #16Golden Member
- Nov 2010
- Gippsland Victoria
- 733
I have read about people putting a grinding cup wheel on a drill press or a round coulmn mill.
The wheel spins in horizontal plane and the drillhead is rotated on the column and the wheel is wiped across the workpiece.
I've got no idea how safe/dangerous this might be - will have a google
Found one, read post #4- https://www.practicalmachinist.com/v...g-mill-177069/
............ and wear your Ned Kelly armoured suit just in case the cup wheel shatters
https://www.youtube.com/watch?v=BrRewbhx8z8
Probably more stuff around with some googling
Bill
4th Aug 2018, 10:50 PM #17Senior Member
- Jun 2016
- 283
I have done this with a cup wheel on a manual mill.
I used a small cup wheel as a big one got bogged down too easily.
I crept up on the Z feed, probably 0.01 mm at a time. Or maybe 0.005 mm.
I was relying on the X axis ways for flatness.
Anything more aggressive simply stalled the motor. There did not seem to be much risk of the cup wheel bursting.
Eh - it worked.
4th Aug 2018, 11:44 PM #18Golden Member
- Nov 2010
- 733
Thanks RCaffin intertesting to hear that somebody has actually done it.Here is other UTube of somebody doing the same as you described https://www.youtube.com/watch?v=soBPKhxpaBg
5th Aug 2018, 09:23 AM #19Senior Member
- Jun 2016
- 283
I used a smaller cup wheel and traversed faster. Didn't have a mag clamp, so had to use jigs. The secret really is to take very fine cuts imho.
I was horrified to see the way all the sparks from the grinding were hitting the Z axis dovetail. Most unwise.
Roger
Help With Flattening Large Saw Blade
By lford250 in forum METALWORK GENERALReplies: 14Last Post: 12th May 2018, 12:51 PM -
Flattening 16mm steel plate for a welding table
By OxxAndBert in forum METALWORK GENERALReplies: 7Last Post: 8th Jan 2018, 07:30 PM -
Hot and cold rolled stock
By morrisman in forum METALWORK GENERALReplies: 5Last Post: 7th Aug 2012, 10:14 PM -
another rolled over tipper
By specialist in forum TRAILERS & OTHER FABRICATED STUFFReplies: 16Last Post: 13th Apr 2011, 10:50 PM -
Flattening a steel plate
By WelderMick in forum METALWORK GENERALReplies: 17Last Post: 2nd Jun 2010, 10:21 PM
