Results 31 to 35 of 35
Thread: Runouts on machinery
2nd Aug 2018, 09:00 PM #31.
- 6,459
Bob,
After the playtime with the Sherline I screwed the 80mm PB Griptru onto the spindle. The fun stopped there. The chuck utilises three tangentially mounted tapered screws to provide concentric adjustment. PB reckon that accurate adjustment can be made within one minute. I obviously need practise but after considerable rooting around I managed to having it running with a repeatable, just under 0.01mm TIR IF I used the key in the same socket. Wrong socket and it was all over the shop. The 5" TOS 3 jaw favours one socket and it's not the factory marked favourite.
Are you mindful of which socket you are using?
Bob.
2nd Aug 2018, 09:10 PM #32Member: Blue and white apron brigade
2nd Aug 2018, 11:46 PM #33Member: Blue and white apron brigade
I tried AB's suggestion of moving the MT arbor around in the socket and measuring the RO
For the first test I decided to use my worst chuck - the keyed chuck that came with the DP, but I did the measurement in the lathe because the DP has a tanged spindle and only provides for two positions of the MT3 arbor.
The next problem is the keyed chuck is an MT2 so it needs an adapter to hold it in the lathe. The adapter is also a tang fit so I can only rotate the MT2 Chuck by 180º in it teh MT2/3 adapater.
I measured the RO at 4 positions separated by a 90º movement of the MT3 (first number in mm) and then rotated the MT2 and repeated the 4 x 90º MT3 rotations again (second number)
Position 1: 0.49 , 0.51
Position 2: 0.39 , 0.49
Position 3: 0.51 , 0.45
Position 4: 0.51 , 0.45
So clearly there is better socket and arbor relationship than others - not that any of them are anything to rave about.
Next I tried my best MT3 keyless chuck in the DP. Because its tanged it only has 2 positions.
Position 1 was 0.045 and position 2 was 0.025 - well worth doing and checking - it should be easy enough to mark the chuck and spindle to keep using the better position.
Next I tried the 4" 3jaw on the lathe and used different chuck socket holes to tighten the bit onto the chuck.
After doing a measurement I removed the bit and turned the scroll by 180º before retightening the bit using a different socket.
First number refers to socket hole and second number is RO in mm.
1: 0.09
2: 0.11
3: 0.03
So a very significant difference - I have marked that hole with a punch character "C" for chuck key.
3rd Aug 2018, 10:08 AM #34Most Valued Member
- Australia east coast
- 2,713
I find it a *lot* easier and less brain-strain to just accept that 3 jaw chucks are convenience tools for turning you're going to do in a single setup using slightly oversized stock. Then the runout is irrelevant.
If I want accuracy on an already machined surface I use a collet or a 4 jaw chuck. My P-B collet chuck gets a lot of use because the collet range goes from 3mm to 40mm in 3mm steps. I might have a 1.5-3mm collet too.
This business of finding the 'right' socket to tighten the 3-jaw chuck - give me a break! I use all the sockets.
I'm *far* more interested in how much taper I'm getting on a shaft. Currently the Chipmaster is down at the 0.0003" in 8" range after I tweaked the headstock a bit.
PDW
4th Aug 2018, 10:05 AM #35Most Valued Member
Here is my mill with 100mm Y between rows. I used my cheapest DTI and not the most rigid setup as I wasn't expecting it to be that close. If I can find a gauge block I might just have another go with a better setup.
Machinery Relocation.
By Machtool in forum METALWORK GENERALReplies: 65Last Post: 27th Nov 2014, 11:26 PM -
More old machinery
By Big Shed in forum METALWORK GENERALReplies: 5Last Post: 16th Sep 2013, 12:20 AM -
CDCO Machinery
By argeng in forum METALWORK GENERALReplies: 21Last Post: 2nd May 2013, 04:05 PM -
SOLD: 1930's 1940's and 1950's English Mechanic's, Machinery Lloyd and Machinery Magazine
By onetwoone in forum METALWORK - Machinery, Equipment, MARKETReplies: 13Last Post: 21st Jan 2013, 07:16 PM -
Diecast on old machinery
By electrosteam in forum METALWORK GENERALReplies: 3Last Post: 9th Aug 2010, 12:18 AM
