Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Jul 2010
    Brisbane
    143
    Round head.. more rounded than dome head I believe... cheese head would be fine also.. depends what is avail
  2. #17
    Nov 2007
    melbourne australia
    3,228
    Now since 3/32" is almost spot on for 7BA, you could use that size.
    Quote Originally Posted by nadroj View Post
    The USA thread 3-48 ASME is another alternative.It's 5.25 thou larger in diameter, but has the same 48 tpi as 3/32 BSW.
    It would be good to have an alternative size in case he doesn't have the 3/32 BSW. The above two posts are in conflict though. According to Google 7BA is 52.92 tpi.
  3. #18
    Jul 2010
    Brisbane
    143
    3-48 would suffice.
    Ken
  4. #19
    Nov 2007
    melbourne australia
    3,228
    No joy, sorry Ken. The closest they had was 3-48 cap screws in black.
  5. #20
    Nov 2008
    Perth WA
    6,459
    Quote Originally Posted by kenny_10 View Post
    Hi all..
    .. to make it more difficult, they have to be bright !
    Ken in Bris.
    Hello Ken,
    If the fixings are only available zinc plated then the zinc can be readily removed with phosphoric acid. BobL, our resident chemist ( amongst other titles ), put me onto Chemtech Rust-Off which has a higher concentration of acid than most other over the counter concoctions. Available from Bunnings and works very effectively at converting those garishly plated fixings to sombre "bright" steel.
    https://www.bunnings.com.au/chemtech...mover_p1107356
    Bob.
  6. #21
    Nov 2007
    melbourne australia
    3,228
    A search of a few UK-based screw suppliers leads me to suspect these things are unobtainable. Making them might be your only option Ken.
  7. #22
    6,480
    Hi Chris, Guys,
    My error ! I looked at diameter and didn't check twice... Sorry for any confusion.
  1. small steel round head slotted wood screws #2, #3, & #4
    Last Post: 26th Nov 2013, 09:08 PM
  2. Small UNC/UNF machine screws
    By Ueee in forum METALWORK GENERAL
    Last Post: 13th Nov 2013, 09:15 PM
  3. Sourcing Aluminium Hex Rod
    By Chris Parks in forum METALWORK GENERAL
    Last Post: 23rd Apr 2013, 10:57 PM
  4. Online supplier of small screws
    By snowyskiesau in forum METALWORK GENERAL
    Last Post: 20th Sep 2010, 03:00 PM
  5. New Website for Sourcing Stuff in Oz
    By hux in forum METALWORK GENERAL
    Last Post: 19th Jan 2008, 11:03 PM
