Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 59
  1. #31
    Dec 2007
    1,628
    240v. 3/4HP. 10Amps 1450rpm
  2. #32
    7,183
    If you have a close look it's 10.4A @110V and 5.2A @ 230V
    That's a pretty old motor 5.2A x 230V = 1200W input and only outputting 3/4HP (560W) output makes it a <50% efficient motor.
  3. #33
    Dec 2007
    1,628
    Default Horizontal Mill Issues
    Is that what it’s saying. I wasn’t sure what all the extra numbers were about but it makes sense now you point it out. Yeah i’d Say it’s very old it had oilers on it which have been broken off, that’s probbably the remains of one in from of the plate in the photo. The mills pretty old too though.
    I don’t imagine the machine is going to get a lot of use (low hobby use) so i’ll Run the motor until the blue smoke escapes.
    I finished assembling the mill it self and made up two new keys one for the table handle and one for the spindle Morse taper. That one is interesting as it has the usual round ends but also a rounded over top.
    As usual you end up with one piece left over you just can’t remember where it belongs?!???
  4. #34
    May 2011
    Murray Bridge S Aust.
    5,945
    That was very confusing, thanks Bob and Dale.
    As I want replace the motor, what would be adviseable, 3/4 or 1/2 horse power, as a minimum?
  5. #35
    7,183
    I only have 1/2HP on my Hercus but I thing 3/4 would be handy.
  6. #36
    Nov 2007
    melbourne australia
    3,228
    Aren't you forgetting power factor Bob? A PF of 0.8 would improve the efficiency to around 60%.
  7. #37
    7,183
    Yeah I do that every time
  8. #38
    6,444
    Hi Kryn,
    Bang a treadmill motor on it ! DC, variable speed and reversible if you want to.
    Oh almost forgot... Cheap
  9. #39
    May 2011
    5,945
    To get a treadmill motor is nearly as expensive as a motor itself, plus how often would I need a reverse on a horizontal mill?
  10. #40
    Dec 2007
    1,628
    Kryn,
    Treadmills are always in the hard rubbish.
    Can you put up some photos of your vertical head please.
  11. #41
    May 2011
    5,945
    Maybe in your area Dale, my area isn't as effluent. The only thing thrown out around here is stolen stuff that didn't sell at a garage sale
  12. #42
    7,183
    The problems with walking machine type DC motors is implementing them into machinery requires either, intimate knowledge about the walking machine's electronics and PS, or purchasing a variable DC power supply.
    For example, the DC motor, control electronics and PS I pulled off a walker has a built in speed reset feature that I have not been able to get around within its own electronic control system. Every time it is stopped the speed goes back to zero so you have to manually reset the speed again. This would be a right PITA on most machines.
    I think VFDs have many advantages for a mill.
    Forward and reverse are standard, ability to setting acceleration and deceleration times, brake, built in jog feature, preset speeds can be had at a flick of a switch.
    The one really useful feature that DC motors is more torque at low speeds has become somewhat less of an issue with the cost of vector control VFDs priced at almost the same as V/F only VFDs.
  13. #43
    Nov 2012
    Mid North Coast NSW
    422
    Quote Originally Posted by DSEL74 View Post
    ALDI All in One interior/ Exterior Metal paint Horizontal Mill Issues
    Aldi had a metal paint a few years ago that was brilliant. I used it on handrails etc outside my place ages ago and it's still good....but...bought some recently and found out it's now water based.....and it's absolute crap ...take it back and get a refund, I did.
  14. #44
    6,444
    Hi Kryn,
    No I wasn't suggesting that you need to be able to run your mill in reverse, just that the motor from a treadmill was reversible, simply by swapping supply polarity ! The implication I was making was that which ever way the motor needed to run to suit your machine, changing it was easy to do.
  15. #45
    6,444
    Hi Bob,
    Maybe this will interest you ! I did try to find the place that I originally downloaded the article from, without successes. So here is the pdf file.
    Terrys_Dual_555_MC_2100_Driver_Circuit.pdf
  1. CNC'ing my mill - electrical issues
    By j3dprints in forum METALWORK GENERAL
    Last Post: 8th Apr 2018, 04:11 PM
  2. Horizontal Mill
    By shedhappens in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 25th Sep 2017, 06:49 PM
  3. Can you identify this horizontal mill?
    By lgftsa in forum ANTIQUE AND VINTAGE MACHINERY
    Last Post: 5th Sep 2016, 08:03 PM
  4. Horizontal mill, what make is this one???
    By Dave J in forum METALWORK GENERAL
    Last Post: 22nd May 2012, 08:15 PM
  5. Assessing old horizontal mill
    Last Post: 6th Dec 2010, 04:29 PM
