Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 59
  1. #16
    Apr 2014
    134
    dean
    why dont you use a link belt instead of pulling the spindle out
    steve
  2. #17
    Dec 2007
    1,628
    The cost of the link belts is astronomical.
  3. #18
    Jul 2016
    35
    1,522
    Probably a good idea to look at all the bearings and journals at the time anyway
  4. #19
    Dec 2007
    1,628
    Now all that’s left is the spindle.
    This same model mill was posted to the forum with a gumtree link.
    The one for sale has the original base, and motor mount. Also look like it has an additional arbor and box of cutters included.
    Looks like originally it was a there speed flat belt.
    Another one only the base is different.
  5. #20
    Sep 2016
    Canberra
    89
    HI again, I see you found pics of my mills.
    I have measured the bases for you. One is 540mm high & the other is 560mm high.
    The taper in both machines I have is a MT3. I measured both arbours and the large end of the taper comes in a 0.93". The tapers appear to be short on the arbour so the small end of the taper at the little end is just slightly larger than 0.79" (as opposed to 0.77") but to the best of my knowledge I don't believe there are any other tapers out there with those dimensions. And those measurements fit with MT3. (IF someone wishes to correct me then by all means feel free to chime in)
    I have also put an MT3 collet in the spindle and it fits like a glove.
    Having said all that, I would still double check yours. Machines were often available with different tapers as options (and still are)
    I will post some photos of the motors mounts for soon.
    Hope this helps
    Matthew
  6. #21
    Sep 2016
    Canberra
    89
  7. #22
    Sep 2016
    Canberra
    89
    Here is the older one. Waiting for restoration. It's motor bracket and countershaft actually mount to the top of the stand.
  8. #23
    Dec 2007
    1,628
    Default Horizontal Mill Issues
    This is what I have done for a motor mount.
    I was feeling a bit better today and the sun was out so while the kid played I degreased, polished and painted some parts.
    Seems like the worlds worst paint, it really tacky so it’s either to thick or the brush wipes it off again. I’ll see if it self levels or I have to strip it off again. It is very different to any paint I’ve used before. I am not convinced thinning it will help much either.
  9. #24
    Aug 2015
    Melbourne, Australia
    843
    What is the paint?
  10. #25
    Dec 2007
    1,628
    Quote Originally Posted by StrayAlien View Post
    What is the paint?
    ALDI All in One interior/ Exterior Metal paint Horizontal Mill Issues🤫
  11. #26
    6,480
    Hi Dean, Guys,
    I don't know if the paint they sell here in the UK is the same, but I've used it several times and found it very good. It does take quite a while to dry. From memory I think it says 8 to 16 hours on the tin. It seems to self level somewhat. But when hard it takes some hammer and doesn't chip easily.
  12. #27
    Aug 2015
    843
    Quote Originally Posted by DSEL74 View Post
    Late reply, but that made me smile ... )
  13. #28
    Dec 2007
    1,628
    Going grey
  14. #29
    Dec 2007
    1,628
    Paints not fully cured and it needs some touch ups around the table. I have go buy a small brush. But I’m impatient to get it finished.
  15. #30
    May 2011
    Murray Bridge S Aust.
    5,959
    What voltage and size motor are you running on this, please?
    I have one the same, but a flat belt, thinking of going the V belt route also.
    I do have a vertical head for mine, if you want to copy one?
  1. CNC'ing my mill - electrical issues
    By j3dprints in forum METALWORK GENERAL
    Last Post: 8th Apr 2018, 04:11 PM
  2. Horizontal Mill
    By shedhappens in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 25th Sep 2017, 06:49 PM
  3. Can you identify this horizontal mill?
    By lgftsa in forum ANTIQUE AND VINTAGE MACHINERY
    Last Post: 5th Sep 2016, 08:03 PM
  4. Horizontal mill, what make is this one???
    By Dave J in forum METALWORK GENERAL
    Last Post: 22nd May 2012, 08:15 PM
  5. Assessing old horizontal mill
    Last Post: 6th Dec 2010, 04:29 PM
