Results 31 to 35 of 35
Thread: plain bearing material.
27th Jul 2018, 12:53 PM #31Senior Member
- Sep 2007
- Country West Oz
- 77
- 169
It could be the blade you are using.
The blade I use is 6.35mm wide and I think about 6tpi, wider or finer blades may cause heat and therefore melting.Regards
Bradford
27th Jul 2018, 07:08 PM #32Banned
- Jan 2018
- Aldinga Beach.
- 73
- 148
No go with Delrin. Turned down a couple of inner bushes today, inserted the and found they compress - lots. Brass/bronze it is. Hate turning this stuff, so damn messy.
27th Jul 2018, 08:06 PM #33Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
May I know why you decided against cast iron?
It is admittedly also messy, but very easy to machine.
27th Jul 2018, 08:51 PM #34Most Valued Member
Are you sure it’s Delrin? If it’s melting when you cut it and compressing under load, I reckon you might have HDPE or nylon.
Sent from my iPhone using TapatalkChris
27th Jul 2018, 09:00 PM #35Banned
- Jan 2018
- Aldinga Beach.
- 73
- 148
Plain Bearing Lathe Spindle lubrication?
By Gammaboy in forum METALWORK GENERALReplies: 6Last Post: 24th Mar 2015, 01:50 PM -
Tidied up Hercus 9A imperial plain bearing model
By jrumbel in forum THE HERCUS AREAReplies: 15Last Post: 4th Dec 2014, 12:20 PM -
Thrust on plain bearing lathes
By Ueee in forum METALWORK GENERALReplies: 23Last Post: 12th Apr 2013, 10:22 AM -
Questions re Plain Headstock Bearings and Way wear
By Vicroamer in forum THE HERCUS AREAReplies: 18Last Post: 2nd Nov 2011, 10:12 PM -
Plain versus roller bearing headstocks
By morrisman in forum THE HERCUS AREAReplies: 9Last Post: 11th Jul 2011, 10:13 PM
