Results 16 to 30 of 37
  1. #16
    6,443
    Hi ViperX85,
    The oil flows out by capillary action ! The ones with a wire down the inside are the same. As long as the wire contacts the sides the oil will flow over the top into the tube. Useful effect, capillary action
  2. #17
    Sep 2011
    Ballarat
    65
    3,103
    Hi Viper
    with regard to the lubrication cups and stuff, I had a similar problem on one of the steam engines I had to get going.
    I used a combination of felt as well as trimmings both plug and tail.
    The outcome was very successful so if you need more pics or info then don't hesitate to ask.
    Phil
    IMG_9697 copy.jpg DSCN0073 copy.JPG IMG_9698 copy.JPG DSCN0077 copy.JPG IMG_9693 copy.JPG Trimmings(1) (Large).jpg
  3. #18
    Dec 2013
    Sydney
    201
    Quote Originally Posted by Viperx85 View Post
    I don't suppose if anyone knows the original paint color of Nuttals? Not sure if the green is the original color or not.
    Viper,
    My Herbert Nuttall had been painted a creamy light green colour (see pics in your other thread) at some stage in it's 77 year life, but underneath was a mid grey colour (see pics here). On this basis I decided to paint mine machinery grey, which matched many other machines in my workshop. This colour is close but not exactly the same as what I found under the cream.
    I was surprised how much filler was under the paint. The manufacturer went to quite some trouble to smooth over casting imperfections and surface roughness. I have replicated this for the re-build, with many layers of polyester bog and hours of sanding.
    Can you see any other colour under the green on yours?
    Graham.
  4. #19
    Jul 2008
    near Warragul, Victoria
    3,718
    I've noticed the same lathe on epay now
    ex munitions commonwealth ...the ways look very rusty
  5. #20
    Apr 2018
    Hobart, Australia
    38
    24
    So was tossing up whether to strip and repaint the machine now or get the motor/VFD first, Decided its likely best to get the motor and VFD first so I can do any modifications to get it running first before repainting it.
    First step was I got a Teco 2.2Kw 4pole 3ph Motor
    Shaft size is larger then original, I removed the original pulley and will have to get it bored out to suit the motor.
    One pair of holes is pretty close and will just have to slot the foot in the motor about half a hole to suit
    Other pair of holes are a fair way off... Debating whether to just drill some new holes in the original mounting surface, Or keep the lathe as original as I can and make up and adapter plate that bolts to the original holes and has holes to suit the motor.
    Will be ordering a Powtrans PI160 VFD next.
  6. #21
    6,443
    Hi Viper,
    I would make up a mounting plate. Would raising the motor 6 or 8 mm make any difference ?
  7. #22
    Apr 2018
    Hobart, Australia
    38
    24
    Im gong to get the pulley machined and fitted first and see where it needs to sit to keep tension on the belt and the belt cover still fit. I guess that will somewhat dictate how/where the motor is mounted.
  8. #23
    Apr 2018
    Hobart, Australia
    38
    24
    Slow progress but got the pulley machined to suit the new motor and milled up an adapter plate out of 10mm aluminum using my chinese cnc router To mount the new motor without having to drill any new holes in the Lathe.
    Next step is setup the VFD
  9. #24
    Feb 2020
    Australia
    51
    8
    Default Nuttall bump
    Hello, am just giving the Nuttall thread a bump in hope for any updates. I have a 1941 in telecom or s.e.c orange, i ditched the gearbox and went for 3hp with vfd and 6 rib serpentine belt, i went with large chinese drip oilers and run 5W synthetic motorcycle oil. I basically drip heaps to much to be sure!
    I get 10 to 900 rpm on direct and 1 to 300rpm with the backgear which is mostly for large drills.
  10. #25
    Dec 2013
    Sydney
    201
    Quote Originally Posted by Wolsy View Post
    Hello, am just giving the Nuttall thread a bump in hope for any updates.....
    Wolsy,
    I have not made any progress on my 1941 Nuttall lathe restoration. Things got very busy at work for me over the past couple of years, and I have not been in the workshop much at all, and not active on this forum either. However, I have now retired and am starting to get the workshop back into some kind of order, and am hoping to get back to the Nuttall restoration soon.
    Can you provide any details of your VFD conversion? Brand and type of VFD? Belt details etc.? And I'd be keen to know what oilers you have used and where you got them from.
    Graham.
  11. #26
    Feb 2020
    Australia
    51
    8
    Sorry for late reply, the cone head machine has gearbox mounted high in the air, my shed had no room for an engine crane to lift that high, so the gearbox was sold and and treadmill motor was fitted with 6 rib poly v belt and Ecotec balancer pulley. This arrangment was too weak, i ditched the treadmill and used 2.2kw 3hp 2800rpm motor with a chinese vfd. Heaps of grunt, the back gear only gets used for large drills or large diameter stuff, there should a photo in my album. Ive no idea how post forum images, i think the website does allow bulk dumping of images to keep costs down, fair enough i guess.
  12. #27
    Aug 2020
    Illawarra
    6
    Hi, I have just bought one of these lathes but it was dismantled,would anybody know the total weight on this model lathe.
    Drsven
  13. #28
    Jul 2016
    35
    1,522
    At a guess based on my later model nuttall about 1.4 to 1.6t
  14. #29
    Aug 2020
    Illawarra
    6
    Hi caskwarrior
    Thanks for your information,
    I will post some photos soon I have completely
    Disassembled the lathe it's in very good condition for its age.
    Apart from the previous owners grandson pulling it to pieces and damaging a few items.
    I was not impressed
    David
  15. #30
    Dec 2013
    Sydney
    201
    Mine sure is heavy, especially with its gearbox and motor mount, but maybe not 1.4t. The later models were geared head I think, so could well be this weight.
    Dr Sven, I have a good photographic recored of mine coming apart if you get stuck with the re-assembly. Mine is still in pieces too, but I've started to make some progress. All the major parts are now painted.
    Graham.
  1. Herbert High Speed Bench Drill restoration
    By mgtoolmaker in forum METALWORK GENERAL
    Last Post: 9th Aug 2014, 06:07 AM
  2. Information on old Nuttall Herbert lathe
    By rlaxton in forum METALWORK GENERAL
    Last Post: 22nd Mar 2012, 11:15 PM
  3. herbert nuttall lathe info
    By mistercartoon in forum METALWORK GENERAL
    Last Post: 28th May 2010, 01:42 AM
  4. Nuttall lathe manual
    By Old Croc in forum METALWORK GENERAL
    Last Post: 1st Sep 2009, 02:41 PM
  5. Nuttall Lathe
    By Debra in forum METALWORK GENERAL
    Last Post: 16th Aug 2008, 11:37 AM
