Results 1 to 5 of 5
    Apr 2008
    Canberra
    805
    Default Shaft size for bearing press fit
    Hi All,
    i am am making a tool post spindle similar to the ones in the workshop practice series books. The bearings I am using are Japanese NsK ones with a 15.00 mm internal diameter. What size should I make the shaft for a light press fit? I have tried consulting the tables available online but got hopelessly lost. The spindle is being designed to hold an er25 collet.
    thanks in advance.
    brendan
    Jun 2007
    sydney ( st marys )
    64
    4,890
    15.005/15.01
    Jan 2016
    Wodonga Vic
    38
    633
    I'm not 100% sure but I think a K6 fit is what you're after
    Shaft= +0.001 to +0.012
    Edit: removed hole tolerance
    Apr 2008
    Canberra
    805
    Thanks fellas. That’s quite a bit smaller than I had in my head so I’m glad I asked.
    brendan
    near Rockhampton
    6,218
    To be honest I would make it a hand push fit, then loctite.
  1. Replies: 3
    Last Post: 23rd Dec 2013, 12:18 PM
  2. Cheap bushing/bearing options for an 85mm shaft?
    By gallegos in forum METALWORK GENERAL
    Last Post: 29th Nov 2013, 04:19 PM
  3. Guide to size of electrode and bead size
    By Tiger in forum WELDING
    Last Post: 10th Jul 2009, 11:45 AM
  4. bearing size
    By weisyboy in forum METALWORK GENERAL
    Last Post: 16th Jun 2008, 08:45 AM
  5. Shaft size for 12mm bearing?
    By warren in forum METALWORK GENERAL
    Last Post: 15th Apr 2007, 11:45 AM
