Results 76 to 90 of 91
25th Jul 2018, 01:07 PM #76Most Valued Member
- 4,890
You have got 2 grub screws holding ,make it a sliding fit and secure with only the grub screws,if concerned put another grub screw in put 2 grub screws together, don't use loctite.
25th Jul 2018, 03:28 PM #77
It's not that I want to use loctite, heaven forbid after wasting 3 days due to some fool who has used it. I think it's now a fair bet it wasn't a factory decision done because of some known issue, rather it was just some whacker who likes putting loctite on everything.
It's that in reassembling it, to make a nice job (though why waste more time is also a good thought), it seems to me that the pulley is too tight a fit on the shaft. A push-fit would be nicer. So, since it's a fine tolerance to go from the current force fit to a push fit, I'm wondering if to use valve-grinding paste to lap the pulley onto the shaft. Or not, since it might just have the effect of bell-mouthing the pulley and/or tapering the shaft, rather than giving me a uniform 1 or 2 thou reduction in diameter.
25th Jul 2018, 03:30 PM #78Most Valued Member
I don't think lapping is an option. Do you know anyone with a lathe in Canberra? I think there's at least one forum member in Canberra. Would be a fairly simple job.
25th Jul 2018, 04:00 PM #79Most Valued Member
- 4,890
Do you have the ability to measure everything so that you have a starting point?
25th Jul 2018, 05:25 PM #80
I have a lathe and micrometers here. I thought given that it was such a small amount to take off that it would be easier to use lapping paste. But I can set it up in the lathe and take a very light boring cut in the pulley.
25th Jul 2018, 05:35 PM #81Most Valued Member
- 4,890
Measure it and see what needs to be taken out, you might be able to knock it off with a bit of emery or a fine flap wheel.
Sent from my T85 using Tapatalk
25th Jul 2018, 06:54 PM #82
Well anyhow while we were discussing that, I was trying to get off the pulley from the cutting head arbor. Drilling out the grub screw (once again, heat did nothing) I noticed again green loctite/whatever glue come out in the swarf. The pulley won't move with heat/puller/impact. I'll have to cut that one off with a 9" grinder. BobL might be right, brick dust water might have gotten into that one. Anyhow, it's tougher than the motor pulley was.
So I'm thinking the replacement might as well be taperlock pulleys. They don't seem too expensive in that size (about 80mm OD). Am I right that I wouldn't need to worry about matching the keyway size, because I can do without a key?
25th Jul 2018, 07:03 PM #83Member: Blue and white apron brigade
25th Jul 2018, 08:51 PM #84Most Valued Member
- 4,258
19mm would be 3/4 imperial. I think metric motors are 20mm...but i stand to be corrected....i dont have the data in front of me as i am using phone
25th Jul 2018, 09:33 PM #85
Both shafts at the pulley are 19mm / 3/4". I'm probably looking at taper lock bushes type 1210 which are commonly stocked for 19mm bore.
Even though the motor is 'high torque', the torque calculated from rpm and rated power is only 5Nm, and the 1210 taper lock bush is rated 407Nm.
If that means the bush is still able to grip the shaft at 407Nm, then I can't see that I'd need a key for 5Nm. That's if I'm interpreting the specs correctly.
The thing is, those 19mm type 1210 bushes come with a 6mm wide keyway, and the existing shafts have 3/16" keyways, so to avoid hassle of re-milling the keyways, I'd go without a key if possible.
However that pans out, the two taper-lock bushes and two taper-lock pulleys combined cost about $40 all up, which is alright. Might even get away with using the old belts.
If I had my time again I would have got out the grinder 3 days ago and cut those pulleys instead of all this fuss - pay $40 instead of 3 days hassle.
25th Jul 2018, 09:41 PM #86Most Valued Member
25th Jul 2018, 09:57 PM #87
Blackwoods website -- https://www.blackwoods.com.au (needs login to see prices).
And backup, PT Parts -- https://www.ptparts.com.au - but they work out to about $55 all up plus delivery.
Both give prices inc GST.
25th Jul 2018, 10:20 PM #88Most Valued Member
How about milling one side of a piece of 6mm key stock to 3/16" (i.e. make a T shaped key)? Like this:
Step Key Oversize Tolerance Assortments | MAK-A-KEYChris
25th Jul 2018, 10:28 PM #89
25th Jul 2018, 11:50 PM #90
[HELP] Stubborn screw thread removal
By typicalabc in forum METALWORK GENERALReplies: 17Last Post: 17th Nov 2017, 11:08 AM -
How to remove screw gear?
By monchochos in forum THE HERCUS AREAReplies: 5Last Post: 1st Sep 2017, 11:10 AM -
Roller grinder ways/ plain grinder ways
By Michael G in forum METALWORK GENERALReplies: 11Last Post: 6th May 2012, 12:37 AM -
What sized motor to power a 100kg screw lift
By 19brendan81 in forum METALWORK GENERALReplies: 7Last Post: 24th Mar 2012, 03:33 PM -
Motor twin pulley dimensions ???
By bitza500 in forum THE HERCUS AREAReplies: 2Last Post: 29th Nov 2008, 04:43 PM
