Results 16 to 30 of 91
21st Jul 2018, 08:10 AM #16Most Valued Member
- Sep 2011
- Ballarat
- 3,103
I reckon I would go with heating the hub as you only need to break the 'seal' for want of a better term.
At least if there is any Loctite in there it will burn it out
Make sure you get it quite hot, almost glowing around the grub screw and try to remove the grub screw while still heating.
Best of luck.
Phil
21st Jul 2018, 09:49 AM #17Most Valued Member
Just a thought:
If the OP gets the pulley near red hot and it still doesn’t come off, that heat is going to make its way into the motor via the shaft. Is there any risk of damage if that happens?
Sent from my iPhone using TapatalkChris
21st Jul 2018, 10:17 AM #18
While I am happy with the advise about heating, and willing to have another go (although all I have is the blowtorch, no oxy, so possibly heat dissipation is my main problem), I have to admit I do have a concern about heat going to where it isn't good.
Of course, the drill stands by as the alternative!
21st Jul 2018, 10:25 AM #19Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Oops. No not that much heat if it's on a motor. Best bet for heat is a welding tip on an oxy acet/LPG torch for pinpoint heat.
Sorry about the previous advice.
Phil
21st Jul 2018, 10:27 AM #20Most Valued Member
- 4,890
In regards to Phillis suggestion if you had suitable heating it might be better to just spot heat rather than heating the whole hub.
21st Jul 2018, 11:04 AM #21Golden Member
- Mar 2009
- 54
- 825
If the pulley is steel and not cast iron, and if you have an arc welder handy, run a short bead of weld radially along the outside of the pulley along where the set screw is located. Try and loosen the set screw while the weld is still hot. Simply grind/machine the weld bead away when you manage to remove the pulley.
Greg.
21st Jul 2018, 11:40 AM #22
21st Jul 2018, 12:32 PM #23
Actually, looking at the pulley, it probably wouldn't have distorted with a bead of arc weld along where the set-screw was. But it's moot now, because after trying again with a pinpoint gas torch burner, and definitely getting the pulley in the set-screw area and as hot as I dared (shaft getting very hot), and even after that, still no movement from the set-screw, I drilled it out and even went into the shaft a little to ensure no burrs or anything from the setscrew that would interfere with the pulley coming off.
But now, with the set-screw out, that pulley won't come off! It's been WD-40'd liberally for days. The pulley puller is pulled up so tight now that I think something will just snap - either the flange of the pulley or the puller. Gaah. What next? It has to come off because the front bearing on the motor is noisy and has to be seen to. The top priority is to preserve the motor, as these bricksaw motors are a long-frame high-torque variety, costing over $500 new.
So - any ideas on difficult pulley removal?
21st Jul 2018, 12:35 PM #24Member: Blue and white apron brigade
Small Blow torch flame on the pulley in the vicinity of the grub screw is my standard method. Loose shielding around the shaft if you want to reduce heat direct onto the shaft, I usually use a piece of thin walled SHS. Sometimes even a hot air gun (650ºC) with a is enough.
Rather than one massive heating episode I use several heat and then cool method as this is what cracks the corrosion between the screw and pulley. If you can't be fagged waiting for it to cooling, a wet rag or ice can be used.
21st Jul 2018, 12:37 PM #25Member: Blue and white apron brigade
Are you heating the pulley while applying the puller?
21st Jul 2018, 12:49 PM #26Most Valued Member
Ways to remove stubborn set screw in motor pulley?
I once had a pulley where a hole had been drilled into the motor shaft to allow the grub screw to penetrate. Is it possible this has been done and there’s still a bit of grub screw in the hole?
I wouldn’t be applying any more heat. Assuming the pulley went on without being heated, it should come off without it. Maybe drill the grub screw hole out completely, then drill and tap a new hole when you eventually get the pulley off.
Good luck.
Edit. Just re read your post. I see you drilled the hole through to the shaft.
Thinking further, maybe the pulley WAS heated to get in on. If so I guess it will need to be heated to get it off.
21st Jul 2018, 01:03 PM #27Most Valued Member
- 4,890
Once again if you can spot heat between pulpy and shaft there shouldn't be enough heat to grow the shaft,
makes you wonder if the thoughts of the pull being heated to put on the shaft why the 2 grub screws.
21st Jul 2018, 01:49 PM #28Most Valued Member
Given the motor is $500 new and single pulleys are quite cheap, it might be prudent to cut the pulley off and buy or turn up a new one.
21st Jul 2018, 01:55 PM #29Most Valued Member
21st Jul 2018, 02:23 PM #30
These have all been useful comments.
Possibly with BobL's advice I could've preserved the set screw by alternate heating/cooling cycles, whereas I just performed one cycle. Anyways, there's still the saw arbor, which again had a set-screw over the key that I was able to remove, and the other is still stuck fast. So I'll try more heating/cooling cycles on that one.
Yeah, motor pulley. Looks like the only non-destructive option is heating the pulley around the shaft, maybe again in cycles, until it comes off. Or not.
It's a double pulley, so if I end up breaking it or spend half a day cutting it off (chunky little thing), it'll cost me getting a new one.
[HELP] Stubborn screw thread removal
By typicalabc in forum METALWORK GENERALReplies: 17Last Post: 17th Nov 2017, 11:08 AM -
How to remove screw gear?
By monchochos in forum THE HERCUS AREAReplies: 5Last Post: 1st Sep 2017, 11:10 AM -
Roller grinder ways/ plain grinder ways
By Michael G in forum METALWORK GENERALReplies: 11Last Post: 6th May 2012, 12:37 AM -
What sized motor to power a 100kg screw lift
By 19brendan81 in forum METALWORK GENERALReplies: 7Last Post: 24th Mar 2012, 03:33 PM -
Motor twin pulley dimensions ???
By bitza500 in forum THE HERCUS AREAReplies: 2Last Post: 29th Nov 2008, 04:43 PM
