Results 1 to 2 of 2
    Nov 2010
    Gippsland Victoria
    733
    Default Terrific taper extraction idea
    Is posted on MEW forum.
    If you don't get it from the screenshot go and have a look on the forum
    Bill
    Apr 2013
    Toowoomba Qld
    401
    Pretty simple idea, a PVC sleeve that wedges between the spindle nose and back of the ER collet nut. You tighten up the collet nut and compress the sleeve.
    Would be pretty important to have the length correct, especially with how it's being done in that photo with the collet still in place. Would get a bit more thread travel if the collet was taken out first.
  1. Water Extraction from Airline
    By ventureoverland in forum METALWORK GENERAL
    Last Post: 3rd Apr 2015, 03:16 PM
  2. Terrific lathe restoration article
    By neksmerj in forum THE HERCUS AREA
    Last Post: 18th Jan 2015, 01:31 PM
  3. Fume extraction - is this setup safe?
    By stu50 in forum WELDING
    Last Post: 8th Dec 2013, 08:30 PM
  4. Metal dust extraction for linisher
    By jack620 in forum METALWORK GENERAL
    Last Post: 27th May 2013, 10:06 AM
