Results 1 to 10 of 10
Thread: Cutting HSS ?
4th Jul 2018, 06:30 PM #1Senior Member
- Victoria, Australia
- 114
Cutting HSS ?
Sometime I need to cut down some 5/16" HSS. I use an angle grinder with just a generic thin blade. It works, but a lot of heat is generated and some discolouring becomes evident. Wonder if someone has first hand experience cutting HSS or the cobalt variant using a method which keeps heat to a minimum and cuts really well?
Thanks,
Tom
4th Jul 2018, 06:48 PM #2Pink 10EE owner
- 6,218
I generally notch it with a cut off disc, then put it in a vice, wrap it in a rag and hit with a hammer so it snaps.
4th Jul 2018, 06:56 PM #3
Hi Tom,
I use a Dremal with a thin disk to put a score line where I need to snap it. Grip it in the big vise jaws so the score line is just proud and then give the end of it it a hard smack with a big hammer and a piece of bar used as a punch. Use a cloth to stop the broken off piece disappearing into that place where you will never find or see it again Don't forget to wear safety glasses, you don't want to get hit in the eyes by any fragments that may bounce around !
RC beat me to itBest Regards:
4th Jul 2018, 07:39 PM #4
There the only 2 ways I know of
Using Tapatalk
4th Jul 2018, 08:16 PM #5Member: Blue and white apron brigade
This is where this little variable speed bench grinder mounted saw comes into its own.
Because there's no angle grinder motor nearby I can use a spray bottle of water to keep the HSS cool - mainly so's I can hold it against the mitre slide..
I even use it to rip pieces of HSS albeit slowly.
4th Jul 2018, 08:39 PM #6Most Valued Member
- 4,890
Just keep doing what you are doing now , the colours not going to hurt , less chance of splinters than hitting it.
4th Jul 2018, 09:30 PM #7Most Valued Member
It's my understanding that the heat generated by grinding is nowhere near enough to affect the hardness of HSS.
I use an angle grinder too, but I'm keen to give the other method a go.
4th Jul 2018, 11:24 PM #8Gear expert in training
- 34
- 1,080
5th Jul 2018, 12:30 AM #9Intermediate Member
- Aug 2000
- 34
You could also try making friends with somebody who has a wire edm machine
My dad used to have one before he sold his business and retired, quite a few off cuts of HSS ended up being recycled into blanks for wood turning tools! Obviously if you had to pay someone this is not really a feasible solution.
8th Jul 2018, 03:31 PM #10Senior Member
- 114
Updating my own thread. I found using my 100mm Hitachi with thin 1mm blades I can rough out HSS without much drama.
Plasma cutting capacity or waterjet cutting connections?
By jhovel in forum METALWORK GENERALReplies: 25Last Post: 4th Apr 2014, 11:06 AM -
Cutting HSS
By Lumber Bunker in forum METALWORK GENERALReplies: 17Last Post: 5th Dec 2007, 06:56 PM -
More on Oxy cutting
By Grahame Collins in forum METALWORK GENERALReplies: 8Last Post: 18th Oct 2007, 05:34 PM
