Results 16 to 30 of 54
Thread: Metalmaster AL330A Owners
23rd Jul 2018, 06:32 PM #16
It's what I regard as solid, although I guess compared to a big industrial lathe it is still a baby.
The geared head is noisier than a belt drive, but if you've been using a geared head lathe then you know that.
The other issue for me is that I have found it very difficult to completely seal the plug at the bottom of the gearbox despite using a copper oil-plug washer, so there's been a slow leak into the tray that is annoying. But I never asked anyone here what the best approach is.
I had cleaned mine right up, took it to bits and repainted it, even sandblasted all the bog off the bed. Only cosmetic I know but it did come up a lot better than the factory finish which was not too good.
Here it is a few years ago, after all the detailing, fresh painted painted in Killrust 'Pewter'. I made the stand because I'm tall and the Hafco stand was way too low.
23rd Jul 2018, 07:41 PM #17Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
That looks bloody nice!
I was lucky, I'm tall and the bloke I'm buying the lathe off is about 6'13" so it's on a nice tall stand, the AL336 at the men's shed is a bit of a back ache after a while, too low for me.
Nice to see what my machine could look like if I put in the time and effort like you have.
23rd Jul 2018, 09:55 PM #18Senior Member
- Apr 2013
- Toowoomba Qld
- 401
Care to share the source where you got it from ?
I bought one a while ago but the taper was off, was just too shallow, got another lathe sitting in the shed waiting repairs with a D1-4 also and it fits well on there but might be because it's an older lathe and probably has a bit more wear on the spindle nose.
I have found that to make the chucks more accurate you need to adjust the fit of the chuck to the spindle nose taper. If the chuck taper is too shallow the back of the chuck doesn't pull up against the flat front of the spindle nose and instead just sits on the taper. If it's too loose then it doesn't locate on the taper. With a bit of net searching you can find the specs but I can't remember them at the moment. I have had to touch up a few chucks and just use a chunk of tool steel, cut the taper on it then use automotive valve grinding paste and lap the chuck to the tool and keep checking it on the spindle nose. You don't have to adjust much on the taper to have the chuck sit on the spindle nose properly.
23rd Jul 2018, 10:43 PM #19Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
This is the one I purchased https://www.ebay.com.au/itm/ER40-Col...72.m2749.l2649
I haven't tested it properly yet so I can't vouch for it, but the finish does look good, if anything lets me down it'll probably be the collets I purchased from ePay
24th Jul 2018, 02:09 AM #20
Hi Gunnaduit,
Wrap a few turns of PTFE (Plumbers Tape) around the threads of the plug. Don't forget to wrap the tape clockwise looking at the threaded end.Best Regards:
24th Jul 2018, 09:13 AM #21
24th Jul 2018, 10:02 AM #22
26th Jul 2018, 05:57 PM #23Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Was a productive morning today, A friend and I picked up the AL 330A and got it into position at my place, next job will be stripping it down and cleaning it up
26th Jul 2018, 06:34 PM #24
Hi Nedshead,
Congratulations on becoming a member of the 12 x 36 club.
6th Aug 2018, 09:29 PM #25Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Would I be correct in thinking the tool post should float freely in the large T slot in this AL330A compound? I want to pull the compound rest apart and give it a good clean and oil, I gave it a few light taps with a brass drift but it didn't budge and I'm reluctant to give it some good blows in case it's not suppose to move.
Q: How do I remove the tool post stem and do I need to remove the compound hand wheel to disassemble the compound rest?
6th Aug 2018, 09:33 PM #26Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Never-mind Q1, I just spotted the flats on the stem in the photograph
7th Aug 2018, 07:37 PM #27
7th Aug 2018, 08:56 PM #28Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
G'day BaronJ,
Yeah it lifts out, it's a tight fit, I had to grip it with a pair of needle nose pliers and lift and twist it out.
I was going to completely strip the compound but I think I'll leave it as it is and work on removing the carriage, I removed the lead screw/feed rod assembly this arvo and tomorrow I'll remove the carriage.
8th Aug 2018, 06:40 PM #29Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Slipped the carriage off today, cleaned it up and put it back on, I might have the lathe up and running later tonight!
8th Aug 2018, 11:28 PM #30Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Is the quick change feedbox oil bath separate from the headstock in the AL330A?
I drained the oil from the feedbox via the drain plug under it but now I'm wondering if the two are separate, according to the manual, the headstock drain plug is near the oil sight glass but that doesn't seem right, it looks more like a filler plug for the feedbox gears,
I put a little bit of fresh oil in the headstock while I had the drain plug under the feedbox removed but nothing flowed out the plug
Internal Pics of Token tools Metalmaster AC DC 210 Tig
By bj48 in forum WELDINGReplies: 6Last Post: 1st Oct 2018, 11:38 PM -
FS - Damaged Hafco (Metalmaster) AL330A - Manufactured 2004
By deads in forum METALWORK - Machinery, Equipment, MARKETReplies: 10Last Post: 12th Nov 2017, 05:40 PM -
AL330A Cross Slide Removal Help!
By triton2 in forum METALWORK GENERALReplies: 6Last Post: 30th Mar 2017, 11:14 PM -
Metalmaster 210S or Lincoln Speedtec 200C???
By Charger176 in forum WELDINGReplies: 8Last Post: 24th Mar 2017, 12:56 AM -
Aussie AL-960 owners or previous owners input please?
By befuddled in forum METALWORK GENERALReplies: 4Last Post: 6th Jun 2015, 10:14 PM
