Results 1 to 13 of 13
26th Jun 2018, 06:46 PM #1Most Valued Member
- 2,671
Converting a push girder trolley to geared
Wondering if anyone has converted a push girder trolley to a geared one. I've got a few push style ones, the largest being the 2T one on my gantry and would like to convert it to geared with a chain drive to make it easier to move along the beam while loaded.
Looking at photos of geared models, it seems they're essentially the same as the push models but have a very basic spur gear tooth cut into the wheel flanges, and a suitable size pinion mounted between them to drive both wheels at once (as well as obviously a shaft and chainwheel etc...).
Here's an example: https://www.beaver.com.au/materials-handling/materials-handling/push-and-geared-girder-trolleys/beaver-geared-girder-trolley
Anything I'm missing?
26th Jun 2018, 08:11 PM #2Most Valued Member
Steve, on the hidden side you'll probably find some extra reduction gearing. A set up as you've shown, will probably be OK for 500kg. Anything heavier would need extra gearing as in a chainblock.
26th Jun 2018, 11:26 PM #3
Not helping with your question, but interesting to note that the first benefit Beaver claim in their list is that their units are colour coded for easy identification of capacity. Then they have a spec charge below that indicates both the 10t and 20t units are coloured orange. Maybe colour coding is not what it used to be?
27th Jun 2018, 12:09 AM #4Most Valued Member
- 2,671
Good thought, but I've yet to find a photo online of one that looks like it could have extra gearing. Even these photos of the 20T Beaver one don't look like it has any - http://www.graysonline.com/lot/0007-...mm-to-305mm-16
Appears there's enough reduction across the handwheel/pinion/wheel diameter changes anyway.
I must have a look at the shop crane in the maintenance shop at work to see if its got any reduction. Its a 5T dual beam with full carriage rather than a trolley on a single beam, but pretty sure the manual traverse is just a large ~300mm chainwheel.
Malb - I hear what you're saying about the accuracy of the Beaver colour coding statement, but I'm guessing their logic is once you get above 5T its no longer a case of sending the apprentice down to the tool store for a couple of purple chainblocks and some slings to match so they may as well all be the same colour...
27th Jun 2018, 01:22 AM #5Most Valued Member
If you have a small chain block, take off the cover and have a look in there, maybe some useful info there.
Quite possibly it could be direct drive onto the small gear, which then goes onto the main wheel, giving the reduction required. Using a large chain wheel, driving a small gear, onto the main wheel, will reduce the effort required?
When it gets upto the larger units, it would/should be geared down more?
To make one would be a bit hard, as you'd need to make a pulley that will accept the chain, unless you have/obtain one thats stuffed, to use that gear.
27th Jun 2018, 05:29 PM #6
A used commercial roller door chain pulley wheel would be cheap, a roller door place would have them laying around going to scrap, or a scrap yard.
As for the reduction I have looked into modifying one as well, and the 1 to 2 ton all appear to be a gear on each wheel and one in the center attached to a small gear running to the larger chain wheel.
My thoughts where to pick up some used gears and shrink fit then to the wheels, and pin them.Using Tapatalk
27th Jun 2018, 06:48 PM #7Most Valued Member
- 2,671
I checked out the gantry at work today and for reference its ~300mm chainwheel, and a 2:1 reduction driving ~200mm wheels on the carriage. The carriage and wire rope hoist would be close to a tonne on their own I'm guessing.
I've already got feelers out for a used chain pulley at work as I know I've seen them lying around when they've replaced roller door drives. Typically now I'm looking for one there's none about!
Shrinking on some used gears is a good idea, but shouldn't be hard to cut teeth in the flanges.
27th Jun 2018, 07:15 PM #8
As long as you have the diameter of wheels to cut teeth and run on the beam as well.
All the geared one's I've seen have larger diameter wheels and then the gears cut into them, which is why I thought the shrink fit option.
I have 2 new 2 ton machinery house ones that I bought for the wheels for a overhead bridge crane, the wheels are not large enough to cut gears.
I have one older one which does have large wheels, but from memory the flanges are not big enough to do both jobs as the actual running surface is larger.Using Tapatalk
27th Jun 2018, 07:52 PM #9Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
28th Jun 2018, 10:10 AM #10Most Valued Member
- 2,671
28th Jun 2018, 10:15 AM #11
I would have thought you needed a rack on the beam also for the gears to move along?
28th Jun 2018, 02:34 PM #12Most Valued Member
- 2,671
No - the gears just turn the trolley wheels.
29th Jun 2018, 01:17 PM #13Using Tapatalk
Plate grab, girder trolley, 1 ton chain block
By KBs PensNmore in forum METALWORK - Machinery, Equipment, MARKETReplies: 10Last Post: 18th Jan 2018, 02:17 PM -
Converting machine light to LED
By TheNutter in forum METALWORK GENERALReplies: 7Last Post: 22nd Oct 2014, 08:30 PM -
VICTORIA Chain hoist and girder trolley $100
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 14th Apr 2013, 10:15 AM -
Converting to LPG and CO2
By spooled in forum WELDINGReplies: 29Last Post: 27th Jul 2011, 11:30 AM -
Converting circular saw to cut metal
By Pete F in forum METALWORK GENERALReplies: 7Last Post: 16th Jan 2008, 02:35 PM
