Results 1 to 12 of 12
    Jan 2004
    Mackay North Qld
    6,446
    Default Looking for source of 200mm wire brush
    Hi guys,
    Does anyone know an Australian supplier of a good quality 200mm wire brush to fit to my bench grinder?
    American or Euro COO, please! I was not at all, interested in Josco or Flexovit as I knew where they are made.
    I changed my old worn Italian made wire brush, possibly 10 years old for a Bordo, stupidly thinking, well there's a brand I could rely on, believing it was European or American quality. I rapidly disprooved that in moments after the brushes first use, I was showered in wires, lots of them.
    Fortunately, I was wearing my full face shield and my specs so no damage was done.
    It was mounted true with the proper flanges and with the manufacturers spacers and run at 2850 RPMs well under the 4000 rpm max stamped into the wheel flange.
    I know it will be expensive but over many years it is a saving not having to prematurely change poor quality wire wheels.
    Apr 2012
    Healesville
    2,129
    I bought one? with a red centre from the market for $25, it was sooooo out of balance things started walking off the bench.
    I bought another for about $40 from the local engineers supplies with no probs, I will have a look at the names on them and let you know tomorrow.
    cheers, shed
    7,189
    I think it might have been me that put you onto the Bordo? If so I think I did say I was not sure of their origin.
    Anyway another search has turned up USA wire wheels for US$18
    Wire Brushes, Cups and Wheels - Supergrit
    And they ship overseas - be interesting to what they charge to ship.
    I'm quite happy with the Josco wheel I have and I use it a lot. It did throw a lot of wires in the first few uses but it doesn't seem to have thrown any wires in the last year or so - well none that I could detect.
    Jan 2004
    Mackay North Qld
    6,446
    Shedhappens
    Thanks for that!
    On the plus side, the Bordo wheel was in balance but it spat wires out at machine gun frequency. I only used it for a few moments, maybe 30 seconds and shut it down. I have the receipt, so I'll take it back to where I bought it.
    All rotary wire brushes will lose wires in their run in, but they usually do it a couple at a time.
    I could lay into the Italian wire wheel while cleaning a tool and lose the occasional wire but in comparison when the tool I was brushing using the Bordo wheel was ever so lightly touched against the Bordo wheel there was a stacato of wires hitting my face visor. Not good enough!
    My 30-year-old Multitool linisher always had a wire brush mounted on the spare motor spindle and spat the
    occassional wire but none of the brushes I have ever used were in the league of this Bordo for shedding wires.
    Jun 2012
    SA
    1,649
    The last 8" one I got came from Blackwoods. No problems, very little wire loss. Try them.
    Blackwoods also seem very competitive price wise these days. Eg, the wire wheel, and I recently bought some Dinse connectors and an electrode holder from them and they were the cheapest I could find locally.
    The worst that can happen is you will fail.
    But at least you tried.
    Mar 2014
    South of Adelaide
    1,227
    Quote Originally Posted by nearnexus View Post
    What? they actually had something in stock?
    Jun 2012
    SA
    1,649
    I've never found that to be an issue at their Regency Park store.
    Jan 2004
    Mackay North Qld
    6,446
    Hi Rob,
    We have a Blackwoods here in Mackay.
    I shall visit them and see what I can scare up.
    Thanks, mate
    Jan 2004
    Mackay North Qld
    6,446
    Hi BobL
    Thanks for the supergrit link. I have emailed them as to postage costs and will post what I find out in the OFF TOPIC forum.
    Ta Mate
    Jun 2012
    SA
    1,649
    Hi Rob,
    Thanks, mate
    Blackwoods sell Italian SIT brand. Which is what I have. Seems pretty OK to me. This may be the same as you were running originally. They come in a range of widths and wire diameter/density. The smaller diam will tear up much more readily.
    I had a good look around before getting the SIT and everything else looked pretty weak and thin. I used to run some locally made really heavy duty wheels but they shut up shop.
    Cheers Rob
    Apr 2012
    Healesville
    2,129
    Graham this is the Red wire wheel.....do not buy one of these.
    It not only had a bit of runout it is also buckled (ie it wobbles from side to side) I made a flanged bush in an attempt to get some use out of it.
    I really don't know why I still have it as it should have gone in the bin.
    No problems with the Josco.
    cheers, shed
    Jan 2004
    Mackay North Qld
    6,446
    I returned my Bordo wheel and got a refund without problems.
    I rang Blackwoods but after 12 minutes of ads on their 1300 number I got bored.
    My email -through their website -to Slackwoods remains unanswered after 3 days.
    By comparison, my email inquiry to the USA supergrit was answered in under 24 hrs. They did not address the postage cost inquiry.
    I will visit them when I happen to go to that side of town. I still have a new /old stock-10-year-old 150 mm Spanish wheel to use so I will fit that and see how it goes.
  1. Replies: 25
    Last Post: 28th Oct 2014, 07:28 PM
  2. Spare 8" (200mm) 3-jaw chuck anyone?
    Last Post: 23rd Jun 2014, 09:38 AM
  3. VICTORIA Dawn 200mm (8") Bench Vice
    By grumstar in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 2nd Aug 2011, 09:55 PM
  4. source for 2mm aluminium wire
    By Mindabout in forum JEWELLERY
    Last Post: 10th Sep 2006, 11:28 PM
