Results 1 to 6 of 6
    Apr 2017
    Geelong
    27
    Default Leveling milling machine
    I have a Hafco HM50 mill and IM not happy with its level, its not vital to operation but its got a fair lean on it.
    there are a number of outrigger type setups around.
    I think I will go the simplest type likes this
    However am tempted to build a more sophisticated setup like this
    http://i1242.photobucket.com/albums/...psvtz9qwat.jpg
    with the more basic setups what sort of steel would you go 75x20 bar be adequate?
    or does anyone have another suggestion?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Have you already leveled the mill, if so maybe your packers have moved/ shims have moved.
    There should be enough weight in the machine to keep it fixed to the packers currently used.
    If no packers at present and its just sitting on an uneven surface just pack/shim it level.
    Dec 2013
    56
    1,418
    I used 150mm x 150mm RHS packers (lol) with leveling feet, the mill was low for me so I raised it.
    Using Tapatalk
    Dec 2013
    56
    1,418
    Here is a picture without the leveling feet
    Using Tapatalk
    Oct 2011
    Sydney, NSW
    1,249
    I think Photobucket is now known as Suckbucket.
    when I was able to view the photo that adjustable and movable set up looked good.
    Charlestown NSW
    65
    1,673
    Unless its too low for you like Daves was, I'd 2nd what Pipeclay said. Pack/shim it and use it. If you have a few bits of flat bar of various thicknesses, a long pinch bar and some blocks to put under that, it will only take 10 -15 minutes tops.
    peter
  1. Milling machine
    By lamestllama in forum METALWORK GENERAL
    Last Post: 21st Jun 2019, 06:02 PM
  2. VICTORIA Milling Machine
    By ersbruce in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 5th Jun 2012, 02:14 PM
  3. HM- 50 Milling Machine
    By woodfast in forum METALWORK GENERAL
    Last Post: 7th May 2012, 01:05 AM
  4. HM 50 milling machine
    Last Post: 19th Apr 2012, 07:12 PM
  5. Milling machine
    By paulj in forum METALWORK GENERAL
    Last Post: 8th Oct 2011, 10:14 PM
