Results 1 to 14 of 14
    Aug 2012
    Canberra
    75
    4
    Default Kin Shin Metal lathe instructions
    The Hall Men's Shed has had a Kin Shin Metal Lathe KS-3.5fk donated. We need instructions for this lathe in order to operate the lathe properly particularly in turning threads.
    Graham
    Jan 2004
    Mackay North Qld
    6,446
    Hi gmoss
    Welcome to the MetalWork Forum.
    You will find us a helpful bunch with people with knowledge and experience on lathes.
    I can tell you up front many of the Asian manuals do not give instruction on setting up the lathe.
    Basically, they just give a name to the components, supply an exploded view and a parts list if you are lucky.
    The information to cut threads will lay in books like Text Book of Turning by Hercus or The Amateurs lathe by L.H. Spary.
    I did the google thing and found the other names the same lathe was made under, including companies like Grizzly Machinery and Forbes / Hare and Forbes - now Machinery House.
    This particular model lathe has been made under many names, apparently.
    I googled Kin Shin Metal Lathe KS-3.5fk and it leads me to this link:
    Taiwanese Lathes by Brazier's Lantaine, Enco, Wey II Corp, Warco, Peerless, Kin Shin, carolina with Models: 1122, 1124, 1224, 1236, 1340 & 1327 Lathes
    Scroll down the page and see if you can recognize your lathe from the photos.
    Take some photos of your lathe and give us as much info as you can supply and some of the guys here will be able to sort you out as far as single point thread cutting.
    Please! good clear pics of the :
    1. The quick change gearbox. Under, but to the left of the chuck, the thing with 2 levers, and holes for the pins on the levers.
    2. The information grid plates with numbers and letters in the grid boxes. Good clear pics so the info in the grid boxes can be read.
    Some of our blokes- who know much more about lathes than I, shall be along soon to advise you. These pics will help the guys to help you.
    I shall PM some links that will assist you to use our forums and navigate around the different sections.
    Welcome again,
    Jan 2004
    Mackay North Qld
    6,446
    Hi,
    This looks like it, but as I have said there is no thread cutting instruction, in this manual.
    It is branded REX-Cut, but I am pretty sure it is the same lathe.
    I think you will need to join Hobby Machinists - it is free - to gain downloading permission.
    https://www.hobby-machinist.com/reso...340g-pdf.2221/
    Aug 2012
    Canberra
    75
    4
    Hi Grahame,
    I joined the hobby machinists, but when I followed your link there was a message that I do not have authority to access that site. Also I could not find a search button but probably missed it.
    Graham
    Jan 2004
    Mackay North Qld
    6,446
    Hi Graham
    Sometimes they can take a day or so to acknowledge or activate your membership and until that happens you won't have access to their downloads.
    From what I could tell from the UK lathes link, the Kin Shin is a dead spit of all the others on that particular page.
    Same Pattern, different paint and badging. If you PM your email address to me, I will try to send you a copy. The manual is a PDF file and I have no experience in sending one, so anything could happen.
    I any case, the copy is a scan of a photocopy of a photocopy and washed out in places. There was no information contained in this manual about cutting threads.
    This is the UK lathes link to the Kin Shin model and others
    Below is the pic from the scroll down of the page at UK lathes. Hopefully, it is the same as yours. Some of our experience lathe blokes will login eventually to give you a better guide than I can.
    Another thing,is that the guys will need to know what you know about threads ,pitches diameters. It can be difficult assisting someone from scratch, as it were, if they don't have a grasp of the basic principles surrounding threads.
    If you don't have any knowledge of lathes and threads some good info can be picked up on Wikipedia
    https://en.wikipedia.org/wiki/Metal_lathe
    As an aside, regarding the pic of the lathe. There is no way I would lift the lathe like that with the sling around the chuck.
    Also, I noticed there does not seem to be an emergency stop button. That would be a good thing to have fitted.
    Anyway, let us know if this is the lathe.
    Jun 2007
    sydney ( st marys )
    64
    4,887
    Are you chasing information on how to cut a screw thread or how to set the quick change gear box and change gears?
    Aug 2012
    Canberra
    75
    4
    This is the Kin Shin we have.
    Thanks and Regards Graham
    Aug 2012
    Canberra
    75
    4
    We have been using the lathe for basic turning particularly for vehicle restoration. Below is a link to the Hall Collectors ACT site showing some of the work we have been doing
    https://hallcollectors.weebly.com/members-vehicles.html
    One of the guys is part of a clock restoration group and had been been doing basic turning for parts. He now needs to be able to cut a screw thread for some clocks.
    Thanks for your help
    Graham
    Feb 2014
    Werribee, Melbourne
    177
    Graham,
    I have a manual for a Lantaine LAM-350BH that looks very similar - you are welcome to a copy.
    Drop me an email address via PM and I can email you a .pdf (7.5MB). Ray
    Apr 2008
    Canberra
    805
    Hi Graham. I just sent you a PM - I live nearby and would be happy to come out and take a look at your lathe and walk you through the thread cutting process. Ray if you could send me that PDF too I would appreciate it.
    Brendan
    Jan 2004
    Mackay North Qld
    6,446
    The OP has issues sorted by now, I think.
    I happened on this link and thought it may have useful info for other owners of KINSHIN and generic lathes.
    Forbes KS3.5 FK Lathe - Metalworking Fun
    I know of 1 person other looking for info.
    Dec 2005
    Brisbane
    66
    108
    Hi guys, it's been a while, thanks Grahame for linking my lathe pics, is good to know what I have done can some times help some body else, and I can't believe my lathe is even listed in the lathes.co.uk site, I feel all fuzzy inside
    I have been going through my records and found a 63 page manual of this lathe branded Jet it is very poor quality scan , it has a parts list as well, but if it helps I can post the PDF if allowed here? or email it to whom ever wants it,
    and also the usual Lantaine brand manual from the net that everybody refers to,
    Richard.
    Jan 2004
    Mackay North Qld
    6,446
    Hi dano,
    As far as a couple of us in Admin have been able to determine even distributing the copy could be a copyright infringement as we had a similar issue that cropped up a just few days back.
    I haven't elected myself forum policeman but at the same time I do have a duty of care in a way to ensure no members set themselves up for any legal unpleasantness. It all in the Terms of Use- which many have not even bothered to read as yet.
    Speaking to membership in general, each person is responsible for what they post. Read the TOU it spells it out very clearly.
    I don't think there are a lot of those members looking for this manual. I have sent the generic one on to a couple of people but that particular manual is just a glorified parts list.
    My understanding is that members with the particular lathe are looking for is the how to instructional material pertaining to the lathe.
    Should yours have some instructions on various lathe functions it would be welcome to them.
    Perhaps a PM might be handy.If that does not work I would be willing to pass it it to a few members via my Gmail if privately emailed to me. That way it is out sight and doesn't attract too much attention.
    Dano watch for PM PLEASE
    Jan 2004
    Mackay North Qld
    6,446
    attn Jumbo1,
    There are links to the pictures ( lathes UK) in posts 2 & 5.
    Click on them for pics . At the moment my plate is quite full and do not have time to post them.
  1. Setting instructions for MIGOMAG 195 on sheet metal
    By Alf Scotting in forum WELDING
    Last Post: 12th Apr 2015, 02:40 AM
  2. help!! record 148 instructions
    By woodster101 in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 19th Jan 2015, 12:54 AM
  3. Shun Shin SSB 15BH metal lathe
    By flmath in forum METALWORK GENERAL
    Last Post: 8th Mar 2012, 11:36 PM
  4. New toy. Instructions needed.
    By clear out in forum METALWORK GENERAL
    Last Post: 25th Feb 2010, 06:00 AM
  5. Parkerizing instructions
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 22nd Dec 2006, 07:34 AM
