Results 1 to 10 of 10
Thread: Knife Hinges Washer Re-machining
19th Jun 2018, 08:53 PM #1Novice
- May 2018
- 20
I am building a small cabinet that has small 170mm high doors, I am using L-23 Brusso Offset knife hinges. However the washers on the hinges are to big 1.19mm for my small cabinet making the reveal to big.
The door is a veneer plywood core with solid wood edge lipping.
I am looking for someone to machine the washer to a more modest 0.5mm
Here is what the cabinet looks like:
This is what the hinges look like
I do not have a lathe let alone a metal lathe so have no means to reduce the washer, I happy to reimburse you if you can help.
I am in Coburg Melbourne but I can post them to you.
Brusso_Hardware_LLC_Tear_Sheet_L-23.pdf
19th Jun 2018, 10:34 PM #2Member: Blue and white apron brigade
Have you got a belt sander.
Drill a shallow hole in a piece of wood the same diameter and depth as the washer. Place the washer into the hole and sand away.
Periodically stop and check thickness and even-ness of sanding.
I find its easier to thing them this way that to use a lathe.
19th Jun 2018, 10:39 PM #3Novice
- May 2018
- 20
The tenon/spigot and the washer are a single piece and cannot be separated so that will not work. I also do not have a belt sander.
19th Jun 2018, 11:30 PM #4Member: Blue and white apron brigade
20th Jun 2018, 01:19 AM #5Most Valued Member
What is the diameter of the tenon? If it's 1/4", you could try a Pen mill, with a small piece of broken/short drill stub used as the arbor, in the Drill press or hand drill, using a slow speed checking constantly the amount removed.
Have attached an image of a Pen Mill for your reference.
Hope this helps,
20th Jun 2018, 08:54 AM #6Most Valued Member
- Jul 2016
- 35
- 1,522
You could also superglue them both to a board, glue a strip of 1.5mm wood next to them as a file rest and go nuts with a file.
20th Jun 2018, 11:08 AM #7Senior Member
- Aug 2013
- 229
I will have a look at it for you, l will send a pm
Pete
20th Jun 2018, 09:01 PM #8Most Valued Member
20th Jun 2018, 09:14 PM #9
Me thinks that the pin is machined with a shoulder such as
0F373841-596D-47F1-B78F-3E14E4F44305.jpegCheers
DJ
20th Jun 2018, 09:34 PM #10Golden Member
- Oct 2001
- ACT
- 667
should be a simple lathe job. If Pete cant do it for you let me know.
Parts washer for a hand washer?
By j3dprints in forum METALWORK GENERALReplies: 13Last Post: 18th Mar 2018, 09:14 AM -
Superglue and Washer Turning
By Anorak Bob in forum METALWORK GENERALReplies: 49Last Post: 22nd Nov 2012, 07:01 PM -
Brass or bronze washer?
By Woodwould in forum METALWORK GENERALReplies: 14Last Post: 11th Oct 2008, 06:54 PM
