Results 1 to 10 of 10
    Nov 2008
    Perth WA
    6,458
    Default Does Anyone Use Circular Indexable Inserts?
    Before I waste money I thought it might be worth finding out if others use these inserts and how they regard them. Given their increased cutting surface I wonder whether they will function adequately if used on my 2 horsepower mill. Cheap endmills are readily available in one or two cutter configurations.
    https://www.ebay.com.au/itm/10pcs-RP....c100005.m1851
    Bob
    Mar 2014
    South of Adelaide
    1,225
    I use that type of insert in a 50 taper 20hp machining centre at work. Mainly use them for roughing, the large corner radius really helps with tool life.
    I'm not sure how well they would work on a smaller mill, but at that price they would be worth a try, we pay more than that per insert at work.
    Feb 2013
    Laidley, SE Qld
    1,038
    I find them useful on the lathe (14 x 40) from time to time, haven't tried them on the mill.
    6,436
    G,morning Bob,
    Yes I've used them. They are quite good for long surfaces, like a shaft or as I tried in my earlier days, on a fly cutter. After which I went with the disc type and a small HSS tool bit. Easy to make tool holders for the lathe using them as its simply a flat bottomed recess with a tapped hole through the middle. I've got a couple of different types of insert, but don't have a clue what they are, since I have had them given to me. I don't use them much, preferring HSS to carbide. I really should have a play with them some more
    Nov 2008
    Perth WA
    6,458
    Thank you for the replies Ashley, Bob and John.
    Given their price I'll take a punt.
    Bob.
    Jun 2007
    Victoria, Australia
    114
    I used them for finishing passes on tough material. Round HSS also works well on plastics.
    near Rockhampton
    6,216
    Years and years ago I got talked into buying a Iscar chamill face mill. It could take four different shaped cutters. I found the round ones were the best for metal removal.
    Nov 2008
    Perth WA
    6,458
    Quote Originally Posted by topari View Post
    Tom,
    I use CCGT inserts mounted in a cut down boring bar for fly cutting with my boring head. I can only use two corners of the insert. These round inserts could prove to be a pretty economical alternative. I just dropped the grand total of twenty bucks for a pack of ten smaller RPMT08 inserts and a single insert 12mm end mill. It will be interesting to see how well they perform.
    Bob.
    Jun 2011
    Australia east coast
    2,713
    Quote Originally Posted by bob ward View Post
    Same, quite useful for profiling welds to get a nice smooth fillet. Reminds me - I need to buy some more, I broke the last one I had.....
    PDW
    Aug 2011
    4,779
    That looks like a bargain. I might have to look into round cutters too.
  1. Indexable carbide inserts chipping
    By familyguy in forum METALWORK GENERAL
    Last Post: 5th Nov 2017, 12:37 PM
  2. those with indexable lathes/ milling machines
    By iolithblue in forum METALWORK GENERAL
    Last Post: 6th Nov 2015, 11:53 PM
  3. For Andre - Indexable Inserts
    Last Post: 31st May 2012, 09:18 PM
  4. Indexable threading tools
    By steran50 in forum METALWORK GENERAL
    Last Post: 18th Jul 2011, 10:56 PM
  5. Indexable End Mills vs Indexable Face Mills
    By Big Shed in forum METALWORK GENERAL
    Last Post: 9th Dec 2010, 11:05 PM
