Results 16 to 27 of 27
Thread: Premo Mk3 lathe lubrication
8th May 2019, 09:14 PM #16Novice
- May 2009
- Hobart, Tasmania
- 21
The bearings are class 3 timken roller bearings and will be very expensive to replace. I'd be surprised if they need replacing.. I'd machine the backplate off just like pipeclay said. Just turn it like it was any other job. It will most likely be cast iron, but possibly steel. Almost certainly won't be hardened.
Please don't use pipe-wrench like tools, they'll just damage things. The clamp I showed can be tightened as hard as you like and will grip like hell and not damage anything.
I would try heat or penetrating oil. Unless there is a locking pin it will undo, even if there is a hidden pin, it will shear which is probably better than stuffing up the spindle bearings.
As mentioned it's a 2.5" (edit: actually 2 1/4") thread, pretty hefty. Any corrosion will have it on there pretty tight. Also any kind of crash could really lock the chuck on there. Get yourself some big long levers to apply lots of torque with more control.
Craig
8th May 2019, 09:21 PM #17Most Valued Member
- 4,890
If you are going to try heat , I would suggest you remove the chuck and place bolts or pins into the mounting holes in the back plate and then position a long lever of some description between the bolts or pins so that you can apply force to the back plate.
When it comes to heating I would spot heat only to the backing plate about 1" from the spindle , if using oxy should only take a few minutes to get it cherry red , you need to apply force to your lever at the same time.You don't won't to get the sp8ndle as hot as the back plate, you may even consider placing a wet rag in the spindle to try and eliminate it getting to hot.
Once it starts to move keep turning it until it is off.
If heat does not work just machine the backing plate off until you get down to just above the spindle thread, if it the size I think the spindle OD is 1 1/2", so around 1 5/8" should be okay, you may even find that you can take it lower, you should then be able to try monkeys or stillsons on it to unscrew the remainder, when machining it off make sure you don't cut the register face behind the spindle thread.
8th May 2019, 09:29 PM #18Novice
- May 2009
- Hobart, Tasmania
- 21
I just went and measured my dummy spindle nose. Definitely 2.25" X 6tpi. Not 2.5" as I previously mentioned (apologies).
Certainly don't turn it down to 1 5/8", or you may be turning fresh air!
Craig
Sent from my HUAWEI TAG-L22 using Tapatalk
9th May 2019, 10:17 AM #19Most Valued Member
- Australia east coast
- 2,713
Pipeclay is probably thinking about the earlier Premo lathes, which were 1 1/2-8 threaded spindles. I made a new spindle for mine and went to 2 1/4-8 to match the nose on my Smith-Drum.
Then I sold the Premo.....
Agree with pipeclay with the addition that sometimes a hard shock gets things moving when a steady force won't. Smacking the end of a stiff bar with a BIG hammer *provided* the spindle is properly restrained and won't suffer damage may shift things. I think I used a hydraulic jack to break the faceplate free on the Smith-Drum when I first got it. I wasn't turning *that* off, it was 28" diameter cast iron.
PDW
9th May 2019, 10:20 PM #20New Member
- May 2019
- Wollongong
- 9
9th May 2019, 10:41 PM #21Most Valued Member
- Healesville
- 2,129
Sounds like a lot of mucking around.
I would weld a socket to it and hit it with a rattle gun while it is still hot from the weld.
cheers, shed
10th May 2019, 09:43 AM #22Most Valued Member
- Healesville
- 2,129
If think that would be a bit of a bush job then bolt a bit of plate to the backing plate with a large bolt welded in centre of that, disengauge your gear train and impact it.
You like wont need any heat and any shock from the impact gun into your brgs would be far less that when doing an inerupted cut.
Cheers, shed
10th May 2019, 02:43 PM #23
Heat
Been through this with a vintage Holbrook lathe. Heat cool heat cool more the better. I shoved a wet rag down the spindle . This went on for days but it finally came free . Be patient very important. The repeated heating cooling cycles will do the job . I locked the spindle by inserting a chuck jaw between
the headstock casing and a gear. Its all described in a thread on this forum...//metalworkforums.com/f65/t1967...Holbrook+stuck
13th May 2019, 04:44 PM #24New Member
- May 2019
- Wollongong
- 9
thread direction
Im at that point where im questioning everything, before i resort to machining it off, which way do i have to turn it to loosen it, would i have to turn it towards me(me being in a operational position) (left, looking at the headstock from the tail stock) or away from me (right, looking at the head stock from the tailstock).
13th May 2019, 07:33 PM #25Most Valued Member
- Jul 2016
- 35
- 1,522
Looking from the tailstock turn it counterclockwise (left).
13th May 2019, 08:29 PM #26New Member
- May 2019
- Wollongong
- 9
26th Jun 2020, 02:15 AM #27Intermediate Member
- Jun 2020
- Bacchus Marsh, victoria
- 27
My MK2 5.5 inch premo has a 1 3/4 inch shaft. Getting the chuck off was difficult, but I engaged the back gears and applied steady pressure to the chuck with a long bar and it came off. BUT it was fairly tight which I did not expect.
Am rebuilding the lathe currently and will look at this tightness aspect when I attend to the headstock.
The headstock alignment uses 4 adjustable screws in the bed. It should be fairly straightforward to align the headstock. Famous last words I hope NOT.
rumpfy
Premo Lathe
By Garry Edwards in forum METALWORK GENERALReplies: 23Last Post: 26th Jun 2020, 01:49 AM -
Change gears for Premo lathe
By Ruddy in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 1st Apr 2017, 10:03 PM -
Premo lathe
By morrisman in forum METALWORK GENERALReplies: 4Last Post: 20th Nov 2011, 08:21 AM -
