Results 1 to 12 of 12
Thread: Rust preventative paper
14th Jun 2018, 04:36 PM #1China
- Dec 2005
- South Australia
- 1,658
Hi all
Does any one know of a supplier for the rust preventative paper that used to be included in boxed items e.g. early Moore&Wright products
14th Jun 2018, 08:27 PM #2Diamond Member
- N.W.Tasmania
- 1,407
G'day China, have a look for vci paper on eBay, plenty of paper mostly from the UK. Quite a range of sizes and prices, as,well as complete rolls.
14th Jun 2018, 08:41 PM #3Most Valued Member
Found this on Brownells website if you're after a small lot. $9.99 for 10 sheets 12"square, or $24.99 for 50 sheets, US$ of course.
https://www.brownells.com/gunsmith-t...-prod1197.aspx
14th Jun 2018, 09:58 PM #4
If you are not quick enough (1st July) similar paper can be obtained here.
Products - VCI Papers & Barrier Wraps - Australian Inhibitor
In the good old days it was referred to as VPI paper- Vapor Phase Inhibitor paper and cased, good quality handtools were wrapped in it. No rust spots on new tools then.
14th Jun 2018, 11:09 PM #5China
- Dec 2005
- South Australia
- 1,658
Thanks all for the info, don't tell me you Googled it, I tried that
14th Jun 2018, 11:11 PM #6China
- Dec 2005
- South Australia
- 1,658
This GST thing is real PIA two companies in the states will no longer deal with me
15th Jun 2018, 07:51 AM #7
Hi China
Allright then I won't tell you I googled it.
But, if I did, I would have used the term "Vapour Phase Inhibitor" as that is what they called the stuff in the good old days.
All jokes aside, sometimes if you simply rephrase the search term or switch the words about, athe desired result can be found.
15th Jun 2018, 01:45 PM #8China
- Dec 2005
- South Australia
- 1,658
Ah yes I did not know the correct name for it I probably should have persevered a bit bit longer
15th Jun 2018, 09:00 PM #9Senior Member
- Jun 2016
- 283
Have you tried brown paper and machine oil? Not perfect, but a shade cheaper.
Or brown paper and silicone oil.
Roger
16th Jun 2018, 12:35 AM #10
Actually, brown paper and lanolin works well !Best Regards:
17th Jun 2018, 07:49 PM #11Novice
- Jul 2016
- tasmania
- 16
If you have a local Caterpillar dealer, might be worth just asking them if you can have the rust inhibiting paper that all their parts come wrapped in. I work at a dealer in Tassie and a majority of our parts come wrapped, some of which have over a square meter of paper, all of which just goes straight in the bin. I don't know how friendly they are over there, but may be worth a shot, especially for free!
18th Jun 2018, 04:38 AM #12Senior Member
- Aug 2007
- 292
There is a VCI plastic version of the paper but I can't find small amounts for sale. Usually sold as bags, some with ziplock closures, or long tubes. The place I once worked used lots to package aircraft parts being sent out to processors. Usually a blue colour so if you are dumpster diving you may find some.
collet chuck or paper weight.
By azzrock in forum METALWORK GENERALReplies: 10Last Post: 18th May 2013, 08:27 PM -
Rust removal Evapo-Rust
By neksmerj in forum METALWORK GENERALReplies: 7Last Post: 22nd Jul 2012, 01:26 AM -
DAM Rust....
By Nurgle in forum METALWORK GENERALReplies: 24Last Post: 9th Oct 2011, 05:17 PM -
what is that anti rust paper called.?
By Nurgle in forum METALWORK GENERALReplies: 4Last Post: 20th Apr 2009, 11:42 PM
