Results 1 to 3 of 3
Thread: Help needed
13th Jun 2018, 08:37 PM #1Most Valued Member
Help needed
I hope this is OK with the moderators.
Found this on our sister forum, someone needing a hand in Sydney.
http://www.woodworkforums.com/f170/help-221828
A copy of which is below;
I tried posting this in the hand/tools Jigs section but only got a response to post in metalwork forum which I cant seem to be able to get into but does anyone out there have a milling machine that can pop a few holes in a piece of 25mm wide x 10mm thick aluminium flat bar? I'll throw in a case of beer as an appetiser.
I don't have the capability to drill and tap these holes accurately enough. They need to be drilled spaced and aligned accurately. I can send a plan and the correct taps for the job, (taps boomerang of course).
if no one can help, can someone point me to an engineering firm near Artarmon, NSW, that they think can do it relatively cheaply.
thanks in advance
Richard
PS. I could up grade to a bottle of Bourbon if that's your thing......
13th Jun 2018, 08:57 PM #2Most Valued Member
- 70
- 1,514
13th Jun 2018, 09:33 PM #3
I don't mind.
That why we are here!
To assist and educate.
Help needed with DRO set up
By TED C in forum METALWORK GENERALReplies: 6Last Post: 16th Jun 2015, 03:51 PM -
help needed
By kdalton1 in forum WELDINGReplies: 10Last Post: 27th Apr 2015, 08:47 PM -
What is this? Help needed
By plantagenon in forum METALWORK GENERALReplies: 4Last Post: 16th Dec 2013, 09:20 AM -
Help needed.
By bwal74 in forum THE HERCUS AREAReplies: 11Last Post: 8th Jan 2012, 10:52 AM -
help needed!!!!!
By bowl-basher in forum METALWORK GENERALReplies: 4Last Post: 12th Aug 2010, 06:45 PM
