Results 1 to 11 of 11
11th Jun 2018, 08:52 PM #1Most Valued Member
Help needed from any Bridgeport owners
Hi all.
On and off im slowly putting together my Pacific FTV-2 milling machine. Parts are still readily available from Lagun (US name of same mill) but for some reason the prices are much higher than the equivalent price and part of a Bridgeport machine.
One such part i have previously repaired to some degree of success is a part called the Clutch Handle Support. It had one tab broken off which i fashioned a repair on however, in a lapse of concentration on removing said part, i snapped off the remaining tab. This has now been the catalyst for a complete replacement of this part. I am reasonably confident i can measure and machine a new part but it will be very time consuming. A new replacement part would be hundreds of $ and so out of the question in terms of justification.
However, the equivalent part for a Bridgeport is $US33. Question is, are they interchangeable parts?
Would anyone with a bridgeport be interested in me sending the part to them and do a comparison. Not expecting anyone to take their mill apart but it should be pretty easy to establish if they are dimensionally similar and worth a purchase.
Naturally i will pay postage each way.
Cheers.
11th Jun 2018, 09:25 PM #2Golden Member
- Vic
- 48
- 544
I have the Yeong Chin, and not too sute if it will be the same as the BP or not.
11th Jun 2018, 10:06 PM #3Golden Member
- Apr 2018
- Drouin Vic
- 633
Whereabouts in Melbourne are you Simon? I have a Bridgeport series 1 J-head in bits in my shed, that part is in primer. I commute between home near Drouin and work near Dandenong. Perhaps we could cross paths and I could arrange to have the part with me. If that won't work, I would be more than happy to receive, compare and return your part.
Pete
11th Jun 2018, 10:57 PM #4Most Valued Member
Thanks for the fast replies.
Hi Jack. A quick measure shows that they very similar but not exact. Most of the external measurements are probably not that critical other than the two shaft sizes (which are the same) and the relative distances between the two. One thing that i did measure as being a bit off that may not be compatible is the bolt hole spacing. I measured the inner distance and the outer distance which gives me an average of 41.1mm separation which is smaller than yours.
Bridgeport maybe different again!
Hi Pete. I live in Bittern (Near Hastings on morington peninsula)
I could make my way to Dandenong on a pre arranged time/day.
Cheers.
12th Jun 2018, 07:59 PM #5Golden Member
- Apr 2018
- Drouin Vic
- 633
Simon, I think it might be difficult to meet up given your location; how about if I take the same measurements that Jackaroo has and get back to you with them. Unfortunately I won't be able to do this until Friday though. If it seems close but we're not certain, then it would probably be easier to post it to me for comparison.
12th Jun 2018, 08:33 PM #6Most Valued Member
No worries Pete. Id be happy to post it to you if you are happy with that.
Ill PM you.
12th Jun 2018, 11:12 PM #7Golden Member
- Apr 2018
- Drouin Vic
- 633
No worries Simon, I've PMd you with my address.
14th Jun 2018, 09:27 PM #8Golden Member
- Aug 2015
- Melbourne, Australia
- 843
Pete, you beat me to it. )
Simon, I am pulling down a series 1 2j2 head this week - started last night. The parts should be the same as Pete's but depending on whether Pete's is a 1hp or a 1.5/2hp the top bits are different.
At any rate, if I can help somehow, let me know. I'm in St Kilda area.
Greg.
14th Jun 2018, 09:31 PM #9Most Valued Member
Thanks heaps Greg that maybe a backup plan. I have sent my part to Pete for him to compare parts.
18th Jun 2018, 08:38 PM #10Golden Member
- Apr 2018
- Drouin Vic
- 633
Simon's part arrived in the mail today. Unfortunately, although the two look like the same part at a glance, I was able to establish that the Pacific part differs from the Bridgeport part in almost every dimension.
Photo shows my jottings- excuse the 'clone' tag, I couldn't recall what the mill was! Measuring the distance between the centre-lines of the two shafts was difficult as they are on different axes but they differ by about 80 thou. The cross shaft from the BP actually fits nicely in the bore of the Pacific part although the BP bore is bigger- might just be wear- but the location of the bore in relation to everything else is different.
18th Jun 2018, 09:38 PM #11Most Valued Member
Thanks heaps Pete.
So every cloud has a silver lining. While I cant take the easy road by simply puchasing the equivalent bridgeport part for about $40, i now look forward to making the part from scratch. Initially when Michael suggested this, i was overwhelmed by that idea. However when you look at the critical components and critical dimensions its not all thaf bad. Much of the external shape is asthetic and near enough should be fine.
Ill post the updates in the thread on the mill in projects.
Bridgeport x-axis DC motor needed.
By caskwarrior in forum METALWORK GENERALReplies: 5Last Post: 6th Aug 2017, 07:04 PM -
Aussie AL-960 owners or previous owners input please?
By befuddled in forum METALWORK GENERALReplies: 4Last Post: 6th Jun 2015, 10:14 PM -
AL-960B owners needed, herless lathe interchagable parts???
By brendanh in forum METALWORK GENERALReplies: 24Last Post: 9th Feb 2015, 06:55 PM -
for the shaper owners
By fxst in forum METALWORK GENERALReplies: 13Last Post: 19th Apr 2012, 11:27 PM -
24 Hercus Owners and still looking
By bitza500 in forum THE HERCUS AREAReplies: 19Last Post: 24th Dec 2008, 10:39 AM
