Results 1 to 5 of 5
Thread: unknown vise
10th Jun 2018, 11:27 AM #1Senior Member
- Nov 2011
- 103
unknown vise
Hi,
got this 6" vise this week as a freebie, but can not find any brand identification or marking on it. The body is extended down at the front to form a couple of hooks for butting against the front of the bench.
Anyone hazard a guess as to its origin?
10th Jun 2018, 02:48 PM #2
Hi node105,
I'll take a guess then! Back in the day when the TAFE's taught practical foundry work this vice could well have been a practice/ term test piece.
Departments, such as fitting turning and welding fabrication often worked together making bits and pieces for each other, as in the spindle /nut and handle. Mind, I did not see vices in particular, but have seen enough of other TAFE made exam items to suggest this was indeed possible.This was in the late sixties when I was attending TAFE as an apprentice.
I do like the vice and would love to see more pics in the case you may have intentions of refurbishing the vice
10th Jun 2018, 04:09 PM #3Senior Member
- Nov 2011
- 103
thanks Graham, that sounds plausible. The vice came from an estate where the old chap had a mechanic's workshop at home for donkey's years; pit, gantry, lathe, 6ft hydraulic trolley jack 3 phase compressor , 3 phase rider, welding...
I thought the brass spindle nut was a bit curious too. I will dissemble and clean it up and see if there might be some initials letter punched under the (?) filler and paint. Seems like a heck of a casting though even for a TAFE apprentice.
thanks for the guess )
I am disinclined to move it on, despite two other 6"Dawns, and others.
10th Jun 2018, 04:58 PM #4Most Valued Member
- 5,942
When you decide to "move it on" please let me know, as I wouldn't mind a cast vise.
I was going to say that it could be from the war, but with the bog filler, I doubt that being the case.
I have an Arnold touch up gun, minus the pot if you want it?
10th Jun 2018, 09:17 PM #5Senior Member
- Nov 2011
- 103
Help getting brushes for an unknown motor?
By j3dprints in forum METALWORK GENERALReplies: 11Last Post: 10th Dec 2017, 12:58 AM -
Collet chuck.unknown use.
By azzrock in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 15th Mar 2017, 07:58 PM -
Electric Furnace ... unknown control
By Vernonv in forum THE FOUNDRYReplies: 9Last Post: 15th Mar 2016, 06:52 PM -
Unknown brazing rods
By phelum in forum WELDINGReplies: 0Last Post: 4th Apr 2012, 07:24 PM -
Unknown Tool Steel
By RayG in forum METALWORK GENERALReplies: 23Last Post: 26th Sep 2011, 10:34 PM
