Results 1 to 6 of 6
Thread: How often do you nod your head?
7th Jun 2018, 08:16 PM #1Golden Member
- Apr 2018
- Drouin Vic
- 634
Hello all, I'm planning a frankenmill conversion, grafting a J-head onto my Victoria U2. The U2 is a nice horizontal mill with power feeds on all axes but the vertical adaptor lacks a quill, a friend from another forum found a J-head needing some love so I jumped at it.
Other things keep getting in the way of actual progress on the conversion but it's been getting a fair bit of mental planning. I am in two minds about incorporating the nod adjustment into it; it will be a lot more work to do this so I am wondering what sort of use the nod might get, what sort of work it is essential for, etc. There are enough mills with tilt but no nod out there that I wonder whether it is useful enough to justify the extra work? Given the amount of time I have not had so far this year, the extra work will probably set the project back several months.
So, to nod or not to nod?
7th Jun 2018, 09:22 PM #2Member
- Dec 2014
- melbourne
- 72
No.
Much better to have a tilting angle plate.
Robert
7th Jun 2018, 09:44 PM #3Pink 10EE owner
- 6,218
I nod more then I tilt.
But in saying that a big tilting angle plate would render in a lot of cases not necessary. Depends on what you have at your disposal.Gold, the colour of choice for the discerning person.
7th Jun 2018, 11:27 PM #4Most Valued Member
- Australia east coast
- 2,713
This. I've recently done quite a lot of machining on my Vicky U2 using the horizontal spindle and a 400mm long tilting angle plate I made. Works fine.
When I made up an adaptor to fit a B/port J head to my M head machine I didn't bother with the nod feature and in 20 years I can't say that I've ever missed it. If I did I could have put the M head and knuckle back on anyway.
I'd be interested in how you're planning on fitting the B/port head to the Vicky mill because I've got a spare J head and exactly the same thought. Just need to find the time - my plan was to fit the head to the overarm to maximise Z space.
PDW
7th Jun 2018, 11:38 PM #5Most Valued Member
8th Jun 2018, 12:25 AM #6Golden Member
- Apr 2018
- Drouin Vic
- 634
Thanks for those replies, I think you have collectively talked me out of the need for nodding which is a relief, the project will be much easier without it.
I plan to mount the head to the front end of the overarm, bracing with thick bar along the sides and top of the overarm, these will provide increased frontal area on the end of the overarm. A picture would tell a thousand words but the design exists only in my head at present.
Kryn, below is about the only photo I have of my J-head at present, it's undergoing a (slow) rebuild; the link will give you a better pic from the net, it is the power head from a bridgeport series 1 mill.
http://thumbs4.ebaystatic.com/d/l800...08758367_1.jpg
260 Geared head
By bwal74 in forum THE HERCUS AREAReplies: 1Last Post: 7th May 2018, 12:45 PM -
Hammer head
By eskimo in forum METALWORK GENERALReplies: 6Last Post: 1st Apr 2018, 09:15 PM -
Indexing head or dividing head?
By stevee7270 in forum METALWORK GENERALReplies: 16Last Post: 16th May 2016, 03:13 PM -
By stevee7270 in forum METALWORK GENERALReplies: 1Last Post: 26th Apr 2016, 04:34 PM -
VICTORIA Die Head
By whitem in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 14th Jan 2013, 02:56 PM
