Results 1 to 4 of 4
    Jan 2018
    Aldinga Beach.
    73
    148
    Default Belt grinder build.
    This is the finished belt grinder. Unfortunately, the motor simply doesn't have enough power to spin two belts so I redesigned it as a single belt grinder and did away with the idler drums. If in the future I come across a motor with a little more power, it's a simple matter to just add a drum to the lower left side and a swinging arm with tracker on at top left. The table is adjustable for angle and belts are available with grits ranging from 80 to 1000. I also added rubber feet to stop it dancing around on the table. I got a little careless when facing the table and took a large chunk out, I'll fix that later on. The motor spins the wrong way and swapping wires doesn't change its direction so I just put locking nuts on all spinning parts as a safety precaution.
    Oct 2011
    Sydney, NSW
    1,249
    Nice job. Did you build it from plans, U Tube or from your head?
    Ben.
    Jan 2018
    Aldinga Beach.
    73
    148
    Only work from plans in my head, design as I go. Lots and lots of cut, weld, try and cut, weld and try again until I'm happy. I do some rough drawings of parts but very rarely stick to the plan. Hardest part was getting the grommets in, bugger of a job, had to call in the missus!
    Jan 2018
    Aldinga Beach.
    73
    148
    Some new belts arrived this morning, 240 grit. Sharpened a HSS cutting bit, an absolute breeze to use and super sharp. Far, far better than a stone. The ker-thump every revolution from the join is a bit annoying though!
  1. Twin belt belt grinder.
    By onanonanon in forum METALWORK GENERAL
    Last Post: 18th May 2018, 03:52 PM
  2. Belt grinder/linisher
    By China in forum METALWORK GENERAL
    Last Post: 2nd Jan 2018, 10:33 AM
  3. Surface grinder belt conversion
    Last Post: 5th Nov 2016, 02:41 PM
  4. belts for belt grinder
    Last Post: 20th Jun 2016, 09:23 AM
  5. Do you own an older Multitool belt grinder?
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 9th Aug 2015, 09:51 PM
