Results 1 to 3 of 3
Thread: CC Engineering TCG belt drive
31st May 2018, 11:23 PM #1Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
My Model D TCG arrived with Z section V belt 2 speed pulleys rather than the flat belt drive with which I believe the Model D was originally equipped.
The axes of the spindle and the motor are not parallel, they are about 1.8° out of true, there are no adjustments, its all in how the castings were machined. The motor is what seems to be the original CP 3ph 2850 motor. The shafts are closer together at the drive end and further apart on the work side. The out of parallel doesn't do much for belt life, its a bit of a PITA.
I'm assuming the out of parallel is part of the design and not a machining error and its something to do with the original flat belt drive. Have I got that right? Any thoughts?
1st Jun 2018, 04:30 PM #2China
- Dec 2005
- South Australia
- 1,656
I am guessing it is to stop the flat belt coming off the pulley, on much larger machines you normally put a twist in the belt which achieves the same result
2nd Jun 2018, 03:32 AM #3
Ther must be some way to tension the belt. Could you modify that to correct the motor mount angle? e.g. using shims or filing slots or something like that to change the pivot angle of the motor mount?
Cheers, Joe
X2 Mill Belt Drive
By mahgnia in forum METALWORK GENERALReplies: 7Last Post: 21st Mar 2013, 05:34 PM -
Kondia Mill Drive Belt
By electrosteam in forum METALWORK GENERALReplies: 2Last Post: 30th Aug 2010, 09:55 AM -
How to belt drive just about anything from any engine - DIY
By yachtwork in forum METALWORK GENERALReplies: 0Last Post: 23rd Jan 2010, 03:06 PM -
Drive belt Vintage Lath
By Paddy in forum METALWORK GENERALReplies: 9Last Post: 24th Aug 2008, 10:31 AM -
belt drive or geared head?
By hitachi230 in forum METALWORK GENERALReplies: 3Last Post: 16th Jan 2008, 10:19 PM
