Results 1 to 9 of 9
29th May 2018, 10:15 PM #1Member: Blue and white apron brigade
$50 3" swivel milling vice review
Still sorting out electrics for the Hercus mill.
Meanwhile, under very helpful guidance from Anorak Bob, have been having fun purchasing basic accessories to get me started.
The mill came with a 5" vice shown in the picture below.
Bob suggested I consider purchasing a smaller basic vice like a 2" to maximise the gap between the arbor and the top of the vice. He also suggested to make sure it had a crank and not a knob type handle, and that the vice component be separable from the swivel and still be useful.
I had a look around in the usual places and saw a basic 2" from India but it was over $110 and then this 3" one from Ozmestore for $50 (+$10 delivery).
As you can see its seriously chunky/sturdy for its size.
The handle shaft end is 14 mm hex so could be driven by a standard 14 mm socket.
It's nominally a 3" vice but the jaw length is 80.5 mm
For a budget level vice it's quite well finished with no burrs or rough edges.
The vice can also be separated from the swivel and has T-slot locators both in the bottom of the vice and the swivel which is one thing I wanted.
The T-slot locators blocks are 14 mm wide so too big for my table but it should be easy enough to make up a couple of suitable locators to suit my table
FWIW it even comes with an unsigned Accuracy statement. I haven't checked any of their claims
Backlash is something between 1/24 and 1/12 of a full turn.
The tops of the jaws look like they need pretty well but there is a 0.02 mm difference across the jaw contact line you can feel it with a fingernail.
The sides of the jaws do not align with a complimentary ~0.25mm step on each side.
The max opening is 68.5 mm and when the jaws are opened the main screw is always covered which I think is a good idea.
One thing that could be improved is the handle on the crank which is fixed to the crank and it would be nicer if it perhaps it rotated - still could be fixed without too much trouble.
Despite its short comings I think it has a number of useful features and represents pretty good value for money.
I will probably still buy a 2" sometime in the future, but at least this one will get me started.Last edited by BobL; 20th Oct 2018 at 10:45 PM.
29th May 2018, 11:15 PM #2.
- 6,459
Bob,
To extract more usefulness from the 3" vice you could drill a counterbored hole through the base casing near the jaws and another near the back end of the base to facilitate the installation of a couple of hold down capscrews. The existing mounting holes in the vice base will only allow its mounting with the jaws parallel to the X axis , not the Y.
You could root around setting it up on the angle plate but if you don't have a suitable slot dill or end mill for the counterbore, it might be easier to bring it here.
Bob
29th May 2018, 11:23 PM #3Member: Blue and white apron brigade
30th May 2018, 12:32 AM #4Member
- Aug 2015
- 69
Pretty sure that vice has the mounting holes that Bob is talking about anyway.
I purchased on of these when I first got my mill and it’s nice and small but I do wonder about getting the 6” that magpro are selling on eBay.
2nd Jun 2018, 03:39 AM #5
That 5" vice is a highly sought after Douglas SHAPER VICE! It's not a milling machine vice at all....
Cheers, Joe
2nd Jun 2018, 04:14 AM #6Member: Blue and white apron brigade
2nd Jun 2018, 12:55 PM #7Novice
- Jan 2014
- Perth, Western Australia
- 18
After Hercus took over the shaper from Douglas and it became the Hercus 270 shaper, the shaper vise remained the same, or at least almost identical.
So, that could be a Hercus 270 shaper vise. That might be how it came to be associated with the Hercus mill?
2nd Jun 2018, 01:53 PM #8Senior Member
- Jul 2012
- Griffith NSW
- 435
More likely that both of those machines were purchased and put together in a school. Moving a vice around from one machine to another is common, especially if youre not using the shaper much (and many didnt get run very often at all). Hell, Ive seen teachers swapping tailstocks from one lathe to another...
2nd Jun 2018, 03:20 PM #9Member: Blue and white apron brigade
It did have some mounting holes but would not fit the T-Slot spacing on the Hercus Mill.
I took the vice around to Anorak Bob's place yesterday afternoon and there was JUST enough room on teh base place to open up the holes as short slots so they now fit the Hercus table spacing.
Thanks again Bob.
Milling Vice
By eskimo in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 6th Apr 2017, 09:35 AM -
SOLD: Glacern 5" Milling Vice, as new
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 10Last Post: 9th Aug 2013, 10:58 PM -
Shaper vice and milling vice
By morrisman in forum METALWORK GENERALReplies: 6Last Post: 5th Sep 2012, 12:06 AM -
My "New" old machine vice
By Ueee in forum METALWORK GENERALReplies: 4Last Post: 16th Jul 2012, 10:57 PM -
Milling Vice
By eskimo in forum METALWORK GENERALReplies: 27Last Post: 17th Aug 2011, 06:00 PM
