Results 1 to 15 of 27
Thread: Coat suggestions
25th May 2018, 08:20 PM #1Senior Member
- Nov 2012
- Mid North Coast NSW
- 422
Coat suggestions
I'm going to pour some lead to make several small weights (about 1/2 kilo each) and carry them around in a vest to treat my osteoporosis.
What I want is some suggestions for coating them so I'm not handling the lead all the time.
I think paint won't last long and prob wouldn't stick anyway. Prob need something thick and tough.
25th May 2018, 08:38 PM #2Senior Member
- May 2012
- Vermont 3133 Victoria
- 248
Buy a cheap vacuum sealer from Aldi.
Regards Bruce
25th May 2018, 08:49 PM #3Senior Member
- Nov 2012
- 422
25th May 2018, 09:09 PM #4Philomath in training
- 6,541
Have a look at plastidip - it's a flexible coating so should be more durable
https://plastidip.com/
25th May 2018, 09:25 PM #5Senior Member
- Nov 2012
- 422
25th May 2018, 09:33 PM #6Member: Blue and white apron brigade
- 7,183
Multiple dips in 2 pack epoxy should work.
BTW it doesn't matter if it does not stick super hard (although epoxy will stick very hard) as its completely sealed anyway.
You might need to make the gaps in the lead extra wide to allow for epoxy thickness.
25th May 2018, 09:34 PM #7Member: Blue and white apron brigade
- 7,183
If you wanted a thin hard coating I would get them powder coated.
25th May 2018, 11:16 PM #8Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
Fabricate/machine them from steel and coat them in house paint? 785 kg/m3 vs 1134 kg/m3
25th May 2018, 11:30 PM #9Member: Blue and white apron brigade
- 7,183
Your exposure during the pouring of the molten lead could be orders of magnitude greater than a lifetime of handling.
26th May 2018, 02:06 AM #10China
- Dec 2005
- South Australia
- 1,656
This is a bit off topic but what is the science behind the treatment, when you do the pour make sure you have a fan moving air past you
to give minimum exposure
26th May 2018, 07:06 PM #11Member
- Dec 2010
- Mornington Peninsula
- 97
27th May 2018, 01:38 PM #12Senior Member
- Nov 2012
- 422
I will be pouring in a breeze and staying up wind.
There are many treatments for osteoporosis but the main ones are getting enough calcium and vit D, plus doing exercises with weights.
By carrying weights on my body for longer periods, I am hoping to trick my brain in to thinking I am heavier than what I really am so it will promote more bone growth and hopefully more density. I'm rather frail these days too so I'm hoping it will increase my muscle mass a bit.
27th May 2018, 01:49 PM #13Senior Member
- Nov 2012
- 422
27th May 2018, 01:52 PM #14Senior Member
- Nov 2012
- 422
31st May 2018, 08:46 AM #15Most Valued Member
How much weight did you want to carry? Another option is to just buy a weighted vest that takes small pockets of sand. Very popular in Cross fit etc. These can carry up to about 50Kg. No one uses lead these days for weighted vests for the reasons you mention above.
And, for under $100 why would you bother re-inventing the wheel? Unless of course you want to carry more weight and keep the bulk down.
https://www.ebay.com.au/itm/20KG-50k...item25d984be50
Clamping suggestions please
By jack620 in forum METALWORK GENERALReplies: 11Last Post: 18th Mar 2016, 09:17 PM -
Helpful suggestions please
By rogerjenkins in forum TRAILERS & OTHER FABRICATED STUFFReplies: 9Last Post: 16th May 2011, 12:44 PM -
Clear coat for polished parts
By Bryan in forum METALWORK GENERALReplies: 12Last Post: 10th Feb 2011, 08:57 PM -
Suggestions please
By artme in forum METALWORK GENERALReplies: 10Last Post: 14th Jan 2009, 07:55 PM
