Results 16 to 27 of 27
Thread: Coat suggestions
31st May 2018, 09:16 AM #16Member: Blue and white apron brigade
- 7,183
I have been in a related camp for the last few months. I don't have osteoporosis but a recent blood tests showed I had low levels of vit D so the doc put me on vit D tablets. Meanwhile a condition I have started to take Ca out of my bones and my blood Ca levels took off to the point where it could affect my heart. So stop the Vit D tabs and am now on a low dose of cortisone to calm things down and I have blood tests every 4 weeks. I doubt whether weights will do anything for my bones as I am already about 30kg over weight.
Be careful doing exercises with weights. A mate of mine was training back in the 70's wearing a basic back pack with 3 bricks in it and eventually did his back in. Start light and work up to the heavier ones was what he was advised.
31st May 2018, 03:04 PM #17Senior Member
- Nov 2012
- Mid North Coast NSW
- 422
I am way underweight which is mostly muscle mass loss for me so carrying weights should help I believe. The recommended thing for the bones is lifting weights and using exercise machines. It's the movement under tension and little shocks to your joints etc that help, so check with your doctor but I would say lifting weights would be good for you too. I just want to add carrying weights for extended times to my routine, it's just my idea but I'm sure it will work for me.
I will be starting out small, like say 1Kg and just add another Kg when I feel it's ok to do so. I would expect to build up to around 4-5Kg. If I make 250g weights I can build up a little at a time and add them around my body in a balanced fashion.
Sand sounds ok but then again lead still means a smaller package, and since I intend to wear it so much I want it to be comfortable.
I thought of making a vest out of leather (I have plenty of it) with many pockets so I can spread the weight around my body. A back pack is definitely a bad idea since it will put all of the weight behind the spine and could cause an injury. What I'm attempting to do is imitate an increase in body fat.
31st May 2018, 03:15 PM #18Senior Member
- Nov 2012
- 422
I'm having trouble with the mould.
I made a former from a piece of melamine and screwed 4 pieces of wood to it to make a boundary.
Apparently half and half plaster of paris and cement are a good mix so that's what I did. The mould broke when I tried to remove the positive (3D printed copy of the weight with a 10Deg. taper).
The mix sets so quickly I had trouble getting it into the former and placing the positive piece. It even starts setting while I'm stirring it. Should I have made the mix more runny ?
31st May 2018, 03:35 PM #19Senior Member
- Nov 2012
- 422
31st May 2018, 03:39 PM #20Senior Member
- Nov 2012
- 422
Oh and another question relating to the lead.
So after pouring, the lead with shrink a little, right ?
Lets assume I'm making a lead doughnut. So will the hole in the middle get smaller or larger with shrinkage ?
31st May 2018, 03:41 PM #21Most Valued Member
- Healesville
- 2,129
31st May 2018, 03:58 PM #22Member: Blue and white apron brigade
- 7,183
5th Jun 2018, 01:02 PM #23Senior Member
- Nov 2012
- 422
Well that means moulding with slots wont work too good because it will prob break the mould.
Going back to that doughnut, years ago I tried to drill a 3/8" hole in a 1/2" plate of copper, half way through it suddenly grabbed the drill and it snapped. Right after drilling the broken tip was held fast but when it cooled I pulled it out with my fingers, so I figured the hole got smaller as it heated up.
5th Jun 2018, 02:31 PM #24Most Valued Member
No different to when you want to press the inner race of a tapered roller bearing onto a shaft. A press fit soon becomes a sliding fit with a small amount of heat.
6th Jun 2018, 08:55 AM #25Member: Blue and white apron brigade
- 7,183
That was because of uneven heating - the outside edge of the plate was not as hot as the area around the hole so the metal had nowhere to go but inwards. However that expansion was not the cause of the "bit grab" Copper is notorious for galling onto bits. It softens from the heat of drilling and sticks like Klingon excrement to the bit and itself. Even after a few mm of drilling it can completely seize a bit .
11th Jun 2018, 07:20 PM #26Senior Member
- Nov 2012
- 422
11th Jun 2018, 07:22 PM #27Senior Member
- Nov 2012
- 422
Oh for heaven sake !, and I've just finished moulding my weights. Ha ha ha
https://www.aldi.com.au/en/special-b...18-06-08_15-31
Clamping suggestions please
By jack620 in forum METALWORK GENERALReplies: 11Last Post: 18th Mar 2016, 09:17 PM -
Helpful suggestions please
By rogerjenkins in forum TRAILERS & OTHER FABRICATED STUFFReplies: 9Last Post: 16th May 2011, 12:44 PM -
Clear coat for polished parts
By Bryan in forum METALWORK GENERALReplies: 12Last Post: 10th Feb 2011, 08:57 PM -
Suggestions please
By artme in forum METALWORK GENERALReplies: 10Last Post: 14th Jan 2009, 07:55 PM
