Results 1 to 8 of 8
25th May 2018, 05:53 PM #1Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
help wanted in victoria harbor bc canida
hi every one . i have some simple machining i need done on a aluminum pump body .
is there any one from the victoria harbor area who would like a little bit of work?
aaron
25th May 2018, 07:31 PM #2
Aaron.
Come on mate, a member of your long standing should understand that our members need a bit more info than that.
Machining could encompass either a lathe or a mill. The work may be simple but I am sure most of those considering any work would like an idea of what that work should be as in refacing a flange or a machining a bore or whatever it is.
What the dickens is canida? Google reckons it is Canada misspelt.
I am sure most would welcome some more information.
25th May 2018, 08:04 PM #3Most Valued Member
I'm trying to work out if Aaron's that desperate for work, that he's gone to Canida or he's moved over there?
26th May 2018, 05:49 PM #4Most Valued Member
- Oct 2010
- 1,910
details
good point Graham
The pump is an aluminum bodied diaphragm pump.
The pipe fitting that connects the suction pipe work has broken off.
Its a grey water pump that is driven by a 32v motor via a toothed belt.
i was thinking a effective repair wold be to tap or machine a thread into the pumps body.
1” suction port. and turn a matching pipe fitting to screw into the female thread.
the pump is 40 years old and i believe no spares are available. there are 4 of these pumps onboard
The ship im working on. The spare is now unserviceable .
i can’t post any photo at the moment as we at sea. We pull into victoria harbor soon.
When i say ship i mean 80’ aluminum ketch/research vessel .
The pumps are very quite when running and one is under the timer floor in the captains cabin and one in my cabin.
So the quite operation of these pumps is part of why i would like to keep them operating.
I thought id ask here before trying a commercial machine shop.
hi Kryn how are you? im not desperate for work but my work some times takes me to far off places .
Which i dont mind this adventure started in Honolulu . i probably stay on for a few months and try check out the local wild life.
aaron
26th May 2018, 11:26 PM #5Most Valued Member
Hi Aaron, I didn't realise that your work takes you all over the world. What is it that you do?? Maybe ask the Captain to buy a small lathe and mill, so that you can facilitate repairs at sea.
Regards,
29th May 2018, 09:12 PM #6
I did meet an older ex Pom in Sidney Vancouver Island who had a Myford or three.
He was a bit of an inventor.
My wife’s cousin who is ex coast guard could send us his details if you like.
H.Jimcracks for the rich and/or wealthy. (aka GKB '88)
5th Jun 2018, 12:22 PM #7Most Valued Member
- Oct 2010
- 1,910
5th Jun 2018, 12:24 PM #8Most Valued Member
- Oct 2010
- 1,910
Newbie from near Geelong, Victoria
By OxxAndBert in forum G'day mate - THE WELCOME WAGON -Introduce yourselfReplies: 4Last Post: 26th Jun 2018, 05:21 AM -
Stock Maker Victoria
By cava in forum GUNSMITHINGReplies: 2Last Post: 22nd Dec 2013, 11:09 AM -
Anyone in Victoria who can help out with some boring and how much do you want?
By fudo133 in forum METALWORK GENERALReplies: 20Last Post: 28th Mar 2013, 02:52 AM -
6 x 4 trailer in Victoria, does it need registration?
By Com_VC in forum TRAILERS & OTHER FABRICATED STUFFReplies: 12Last Post: 4th Mar 2011, 07:31 PM -
A Reason why all WANTED ADS are not in the WANTED SECTION
By skot in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 3Last Post: 16th Aug 2010, 11:24 AM
