Results 46 to 60 of 61
Thread: Log Splitter Repair
1st Jun 2018, 05:29 PM #46Most Valued Member
I nearly built the same flange mount system for my log splitter. I always wondered how they managed to weld the flange plate at bang on 90 degrees to the beam so that the ram would not bind when fully extended..... OK so they cheat and use shims. Ahhh shims, is there anything they can't fix?!
1st Jun 2018, 05:44 PM #47Most Valued Member
- Healesville
- 2,129
4th Jun 2018, 06:59 PM #48Most Valued Member
I bolted the ram onto the splitter today. The fully extended ram needs to move about 8mm sideways and 5mm up to align the holes in the clevis and the blade. Based on the ratio of the length of the extended ram and the mounting bolt centres I need a couple of 1mm shims and a couple of 0.5mm shims. It's not critical because there's a fair bit of slop in the clevis/blade joint.
I started the motor and ran the ram back and forth a few times, but each time I got a loud hiss of air from the tank vent hole. Eventually I noticed the fluid in the supply hose was sitting about 100m below the pump. Obviously it isn't priming. I hope I haven't stuffed the pump by running it dry.
Anyone know how to prime these pumps?Chris
4th Jun 2018, 09:13 PM #49Most Valued Member
These pumps should be self priming as they are whats is called a positive displacement pump and can pump fluids and gases. The only reason it would not self prime is if there was not enough fluid in the resevoir. If the damaged ram still has fluid in it and the new ram is empty then the new ram would have had to be filled from the existing fluid in the resevoir and if the resevoir does not hold enough then the fluid level may run below the pump pickup point and not prime.
The hissing air noise maybe the air entering the resevoir to replace the fluid that has left to fill your new ram.
Check the levels and top it up. You should be fine.
4th Jun 2018, 09:17 PM #50Most Valued Member
Shouldn't be a shortage of fluid. We forced all of the fluid out of the original ram back into the tank.
There was definitely air coming OUT of the bleed hole. I could feel it blowing against my leg each time I extended the ram. I did it about 6 times. Air came out the hole every time.Chris
4th Jun 2018, 10:05 PM #51Pink 10EE owner
- 6,218
Is that a tandem gear pump? If so why is one pump plugged off?
5th Jun 2018, 12:10 AM #52Most Valued Member
- Healesville
- 2,129
5th Jun 2018, 12:32 AM #53Most Valued Member
- Healesville
- 2,129
It would be a good idea to make sure that the suction hose is tight, if you are getting air in that pipe while the engine is not running it is an indication that it is loose at the pump.
5th Jun 2018, 07:30 AM #54Most Valued Member
5th Jun 2018, 09:25 AM #55Most Valued Member
OK, I'll get some more oil and top up the tank.
We used blocks of wood and a pinch bar to force the ram into the cylinder with the control valve open and the engine off. It wasn't easy. In hindsight it may have been drawing oil back into the other side of the piston by suction. Although it would have to pull the oil through the stationary pump. Since John now has that ram he holds the answer to the mystery. If you are right the retract side of the cylinder will be full of oil and my oil tank will be about 5L low.Chris
5th Jun 2018, 06:38 PM #56Most Valued Member
I topped the tank up with 5L of hyd oil and the pump primed straight away. Gold star for Simon.
The oil in the tank was above the pickup point before topping up, but obviously not enough to allow the pump to self-prime. Looks like we didn't get the oil out of the ram. Be careful John!
Now I just need to make/buy some shims.Chris
5th Jun 2018, 09:57 PM #57Most Valued Member
Shucks. Thanks Jack. Glad to have been able to help.
12th Jun 2018, 05:34 PM #58Most Valued Member
- Healesville
- 2,129
rod repair
Here is some pic's of the repair, the rod had 2 bends in it, with the v blocks at each end its now .001" runout in the middle, it has .004" runout from the main bend and halfway between that bend and the end at 180 deg it now has .002".
It took about 15 ton of squishing to bend it and more than double that for the short bend.
I wore a groove in the concrete between the press and the plate so that is as good as it gets, good enough for a log splitter and likely better then a new chinese one
It got a new rod seal and clevice.
cheers, shed
ps. if you look at the rod when it is in the chuck you can see an outer ring on the face, that is the hard bit
12th Jun 2018, 05:46 PM #59Most Valued Member
Nice job John. Two questions:
1. What thread did you end up cutting on the end?
2. Was it full of hydraulic oil?
ChrisChris
12th Jun 2018, 06:05 PM #60Most Valued Member
- Healesville
- 2,129
Hydraulic Log Splitter WIP
By simonl in forum METALWORK PROJECTSReplies: 124Last Post: 15th Nov 2018, 06:24 PM -
Log splitter Advice needed
By simonl in forum METALWORK GENERALReplies: 45Last Post: 1st May 2018, 07:46 PM -
Extraordinary Hydraulic Wood Splitter
By Oldneweng in forum GENERAL DISCUSSION / OFF TOPICReplies: 29Last Post: 28th Aug 2017, 10:51 PM -
Firewood Splitter Modifications
By Oldneweng in forum TRAILERS & OTHER FABRICATED STUFFReplies: 45Last Post: 1st Aug 2017, 05:56 PM -
By Geoff Dean in forum METALWORK GENERALReplies: 8Last Post: 15th Apr 2008, 12:01 AM
