Results 1 to 7 of 7
Thread: How heavy is your mag drill?
17th May 2018, 08:48 PM #1Most Valued Member
- Jul 2016
- 35
- 1,522
I recently got a very old (60's maybe) Fein/Finomag magnetic drill for almost no money, and I was excited to put it to use simply because it has about twice the drilling capacity as my Bridgeport. (2 5/8") but that does come at a price because the Finomag (Made by someone other than fein in belgium evidently) Mag base weighs 53 Kilos! I can barely move and there is no way I could get it horizontal without a second person. Are any of the modern mag drills this heavy? Need to eat some more weetbix I guess
17th May 2018, 10:45 PM #2Most Valued Member
If you're going to use it on a fairly regular basis, I'd look at using an engine crane to lift it onto whatever you're wanting to drill.
17th May 2018, 10:56 PM #3Diamond Member
- Aug 2006
- 1,106
That is some excessive weight there! Most modern magnetic drills average at around 10-15kgs with the heaviest being around 25kg but that would be with auto feed and larger diameter drilling capability. At work we use overhead cranes so weight isn't really an issue anyway.
18th May 2018, 01:54 AM #4
I suspect mine weighs about50kg.... its from the 70s. The base weighs about half that and the drill is a 4 speed 1.25Hp monster though...
Cheers, Joe
18th May 2018, 09:56 AM #5Pink 10EE owner
- 6,218
Mine is a Fein and about 10kg, with a capacity of it says 75mm. That is with a rotabroach of course.
4th Jul 2018, 12:51 PM #6Most Valued Member
- Jul 2016
- 35
- 1,522
Really late with the photos but here it is, I am yet to clean it up but the magnet grips albeit not incredibly well (I can break its grip on big i beams) and the drill works. Can anything be done to bring some zip back to the electro magnet?
4th Jul 2018, 01:54 PM #7
Hi. These magnets typically run on DC, produced by a bridge rectifier from the mains AC. If one of the diodes has failed, then the magnet only gets half-wave pulses and looses about half its force. Mine has 4 individual diodes, yours may have a single full-wave rectifier. If it is as old as you think, then there may even be a selenium rectifier in there somewhere. FInd it and replace it with a modern silicone rectifier and try again.
The other big influence to strenght is the flatness of the the bottom of the magnet surface - and the part it hangs on to. Level the magnet surface nice and flat to give it the best chance. A very uneven or rusty surface on the I-Beam will also prevent it hanging on tight. You should not be able to pull it off by hand.Cheers, Joe
New towball ratings for heavy vehicles.
By Karl Robbers in forum TRAILERS & OTHER FABRICATED STUFFReplies: 40Last Post: 23rd Apr 2019, 01:48 PM -
heavy load
By morrisman in forum ANTIQUE AND VINTAGE MACHINERYReplies: 3Last Post: 24th Oct 2017, 02:51 PM -
Heavy duty 1 1/4" Jeffco drill press
By bob ward in forum METALWORK GENERALReplies: 2Last Post: 6th Jul 2017, 12:49 PM -
Further steps in my new heavy duty cnc
By laurent_parti in forum METALWORK GENERALReplies: 0Last Post: 25th Nov 2014, 08:31 PM -
Heavy cutting U tube
By morrisman in forum METALWORK GENERALReplies: 16Last Post: 4th Mar 2012, 11:25 PM
